66 toronado brake conversion?
Old May 4, 2010 | 02:50 PM
BigWelder036's Avatar
Trying to convert drums to disc brakes on my 66 is there a kit for this and if so which brand and what kit to get any info will be useful thanks.
Old May 4, 2010 | 03:46 PM
toro68's Avatar
First you will have to find a parts car (1967-70 Toronado, or Edlo) with disc brakes for the spindles alone (very inporant first step) .
Old May 4, 2010 | 04:20 PM
What do I do after that? And will I also need to change the booster and proportioning valve
Old May 4, 2010 | 07:20 PM
Remove the old parts, install the new ones. The master cylinder must be changed to a disc/drum master cylinder. Drum/drum cars do not have a proportioning valve, so yes, one must be added. If your stock brakes are single circuit, you will probably need a 1967-up booster or you will need to shorten the pushrod between the booster and the master cylinder.
Old May 5, 2010 | 04:42 PM
Hey thanks for the info will help out a lot!
Mocephus
Oct 1, 2021 09:45 AM
bluecab
Aug 6, 2015 08:38 AM
Maverick
Brakes/Hydraulic Systems
Jun 26, 2013 08:21 AM
bluecab
Nov 2, 2011 12:22 PM
elcaminodave
Aug 9, 2009 04:57 PM
