65-70 full sized disc brakes
Old Sep 24, 2016 | 03:03 PM
Classics65's Avatar
I'm sure I'm beating a dead horse here, but I just came across a front disc brake conversion that uses the stock spindles from Baer. With how the front end is designed with the rear steer tie rods etc, could this be a way of getting away from drums? I'm currently converting my 65 starfire into drag car and the drums will work but not preferred. But for a conversion kit that is made to use the stock spindles, shouldn't it work?
Old Sep 25, 2016 | 06:06 AM
I don't understand what the rear steer has to do with the conversion. The 67-70 full size cars were available with disks from the factory. Unfortunately, no one sells replacement rotors for those cars.
I also don't understand why drums don't work for a drag car. Often drag racers prefer drum brakes because you can back the adjusters off to minimize drag during the run. There was even a little-known manual drum brake option for the 1970 W-30 cars for exactly this purpose.
Old Sep 25, 2016 | 11:06 AM
therobski's Avatar
X2 Joe, Classic65 check out this vendor, I believe they can make performance linings for your brake shoes. http://porterfield-brakes.com/catego...Full+Race.html and stay with drums and stop!
D. Yaros
Jan 14, 2016 07:39 PM
2blu442
Jul 18, 2013 11:52 AM
2blu442
Feb 21, 2011 12:29 PM
2blu442
Nov 15, 2010 07:30 PM
2blu442
Aug 17, 2009 06:26 AM
