62 olds project brakes. Need advice
Old Oct 26, 2009 | 10:51 AM
sshriber's Avatar
Working on my 62 super 88 4 door. Mater cylinder and booster are totaly wasted. Pic attached. Has anyone found a replacement or will work application for this? I am not currently interested in a disc conversion. Thanks for the help.
Old Nov 4, 2009 | 03:52 PM
jaunty75's Avatar
The Fusick catalog shows new master cylinders for '61-'63 88s, 98s, and Starfires for $149. Check their website and look for Catalog 19BC.
RockAuto shows a master cylinder for your car for $74.
Neither place shows a power brake booster, though. Fusick's catalog says "due to a lack of good rebuildable cores and other considerations, we are no longer offering to rebuilt power brake units for 1961-64 Oldsmobiles." They suggest looking in places like Hemmings for a rebuilding service.
Old Nov 4, 2009 | 05:05 PM
citcapp's Avatar
Depending on what your goals are you could retrofit a newer GM booster and master cylinder if your not trying to do a original restoration. Just a thought.
Old Nov 6, 2009 | 08:45 AM
dantana's Avatar
We changed our '61 to an 8" double diaphragm booster and dual master cylinder. The wheelhouse had to be modified slightly for clearance. We had to extend the brake pedal mounting bracket back 1.25" and attach a 3/8" x 3/8" eyelet to hook into the new booster. We also had to get a distribution valve from a 60's GM car with dual master cylinder. The rear brakelines had to be changed from 3/16" to 1/4" for this conversion. This made the braking a lot better and much safer. I know that other people have done this type of conversion also. It is probably the least expensive way to go. If you have any questions let us know.
Old Nov 11, 2009 | 04:25 PM
sshriber's Avatar
Dantana, thanks for the tip. I was thinking of going this direction. Nice work on the pedal extension. Was that because of a travel issue? If I need more info ,can I pm you the questions?
Old Nov 17, 2009 | 05:53 AM
dantana's Avatar
The pedal had to be moved back because the rod sticks into the car more than an original. You could extend things on the outside instead but this worked fine for us. I will PM our shop email so we can answer any other questions. Sorry it took a while to respond. I was on a trip to the Dominican Republic. Not a lot of big Oldsmobiles there!
Old Jan 7, 2010 | 02:13 PM
toms1966rgtop's Avatar
Brakes
if you look at my post under toms1966rgtop you will read where I had my dads power booster sent to. I can attest to the workmanship since installing my dads,his linkage hung up and he siad if it was not for the brake upgrade things would have been worse than he imagined
Old Apr 18, 2010 | 01:59 PM
Big Joe P's Avatar
Check usa parts supply if you're still looking. I picked up a rebuilt booster/master cylinder for my '63...
GMfan
May 1, 2014 10:21 AM
72allblackcoupe
Apr 6, 2014 07:20 PM
JarHead1st
Apr 1, 2014 04:33 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
