56 Treadle vac replacement options.
Old Dec 17, 2020 | 09:20 PM
JerryHamon's Avatar
The brake booster on '56 98 4door has failed. Is there a later model booster/MC that will bolt up in the original location? My car has factory air so mounting on the firewall isn't an option. If not, is the Chevy one interchangeable? Thank you.
Old Dec 17, 2020 | 09:54 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Your best bet is to have yours rebuilt. I had mine rebuilt by Karps Power Brakes Service and he does a great job. I am very satisfied.
Old Dec 18, 2020 | 06:56 AM
sysmg's Avatar
I've used Booster Dewy he also does a great job. (aka Power Brake Booster Exchange)) http://boosterdeweyexchange.com/
Old Dec 18, 2020 | 09:48 AM
ignachuck's Avatar
Frank Ignachuck
Welcome!!! How about some pictures of your car with the factory air???
Old Dec 18, 2020 | 04:04 PM
Yellowstatue's Avatar
You forgot to ask about the A/C manifold pics as well.
Old Dec 18, 2020 | 09:00 PM
Tedd Thompson's Avatar
There is no factory easy fix for a treadle vac booster, like others above you would be better off having yours rebuilt. If you are a good fabricator there is a good thread by Olds Dad on a modern booster that is modified to fit a 55 Oldsmobile and it works but takes fab skills to do it.
If you look at your master cylinder/ booster you will notice that it works *** backwards,( pushes to the rear rather than towards the firewall) than a normal master and that is the issue why there isn't a conventual master that converts easily.... Tedd
Old Dec 19, 2020 | 03:05 AM
ignachuck's Avatar
Frank Ignachuck
Talking
That was definitely going to be my next question
Old Jan 5, 2021 | 05:24 PM
vintagepne's Avatar
Another source for your booster for parts or rebuild is Harmon Classic Brakes, www.harmonclassicbrakes.com
brandon reynolds
Aug 27, 2020 08:59 AM
wr1970
Feb 27, 2015 08:22 AM
cobalt
Mar 2, 2014 03:10 PM
Gunthor1
May 28, 2013 04:48 PM
fuxl
Brakes/Hydraulic Systems
Jan 27, 2013 12:36 PM
