49 Olds 88 repair
Old Dec 21, 2008 | 06:27 AM
oldbill's Avatar
Question 49 Olds 88 repair
I have a 1949 - Olds 88 that needs some repair/restoration. The cost of most of the parts I have seen seem outrageous compared to the later (55 or later models). The car is currently original but I am interested in making it drivable, not necessarly keeping it all original. The master cylinder leaks and the accellerator pump in the carb is shot as are the knee action shocks. Is there a repair/rebuild kit for the master cylinder? How hard is it to modify the suspension to accept the later model shock absorbers?
Old Dec 21, 2008 | 07:50 AM
88 coupe's Avatar
Junior Member
Welcome to the site.
Originally Posted by oldbill
…..... The master cylinder leaks and the accelerator pump in the carb is shot ….....
Download Fusicks catalog and check pages 33 and 40.
…..... How hard is it to modify the suspension to accept the later model shock absorbers?
How are your fabrication skills?
Easier to refill them with ATF (or hydraulic jack oil). If they don't leak, you are good to go. If they do, you can try a little brake fluid to soften the seals. Sometimes it works, sometimes it doesn't.
If it doesn't, try Five Points to learn about more options.
My Grey '50 Coupe has its original (rears were rebuilt, and modified, about ten years ago) shocks, and they work just fine.
Norm
Old Dec 21, 2008 | 09:38 AM
oldbill's Avatar
Wink 88 reply
Thanks for your reply. Will check out access to the refill on the shock fluid. It (refill) sure didn't work on the master cylinder, which seems to make fluid disappear, probably thru one of the wheel cylinders.
Old Dec 21, 2008 | 10:20 AM
I would think this would be quite difficult. Have you checked out these websites for parts?
http://www.kanter.com/
http://www.rockauto.com/
Old Dec 21, 2008 | 10:41 AM
redoldsman's Avatar
Proud Viet Nam Veteran
One thing I heard on the knee action shocks was to warm STP (so it will pour) and use it in the shocks. I have not tried it but the source is somebody I have lots of confidence in who has owned a 54 Olds for a number of years.
Old Dec 22, 2008 | 02:42 AM
oldbill's Avatar
mastercylinder repair
Thanks for the info on Fusicks! They show a rebuild kit for the master cylinder. $19 sounds better than $135! After I get the beast to stop I will work on the shocks....
Old Dec 22, 2008 | 05:14 AM
Danny Wiseley's Avatar
You "might as well" do the wheel cylinders at the same time!
Old Dec 22, 2008 | 06:36 AM
88 coupe's Avatar
Junior Member
........ It (refill) sure didn't work on the master cylinder ........
No reason why it should. They are totally different designs, for totally different uses.
Norm,
Jakespeed63
Feb 20, 2011 05:56 AM
Jakespeed63
Feb 20, 2011 05:33 AM
trvguy
Feb 4, 2011 08:00 PM
KQQLCAT
Apr 27, 2010 09:00 AM
1k442
May 20, 2008 06:32 PM
