1971 Cutlass Brake Pedal sticks slighty
Old August 16th, 2016, 02:52 PM
delta254's Avatar
Just wondering if anybody can help me out my brake pedal sticks slightly and when I forget to unstick it leaves my brake lights on and battery dies very embarrassing I have lubed,greased the pedal area up there and still sticks.....any suggestions? Also as I'm driving when I press the brakes the brake pedal sticks and I have to unstick as Im driving or my brake lights stay on its a slight stick I can unstick it with my other foot as I'm driving, Cutlass does have power disc brake conversation on front only. Thanks guys
delta254 is offline
Old August 16th, 2016, 05:41 PM
It's not friction on the brake pedal arm that is the problem. The issue is likely with the master cylinder or vacuum booster.
Fun71 is offline
Old August 16th, 2016, 06:41 PM
Hookers under Hood
76olds's Avatar
X2 with where Kenneth is going with the master or booster. Does the brake pedal go past the gas pedal when your fully breaking?
Is the master cylinder cap gasket all the way out when you take the cap off?Any fluid loss?
When you push the master cap gasket back in after braking several times does the gasket come back out?
Eric
76olds is offline
Old August 17th, 2016, 02:09 PM
delta254's Avatar
Eric
Thanks Eric and Kenneth I will look it at tonight and let you guys know Thanks again.
delta254 is offline
Oldssupreme
June 4th, 2016 07:15 AM
Olds442redberet
July 14th, 2015 12:04 PM
tru-blue 442
February 25th, 2015 06:13 AM
oldspackrat
August 20th, 2014 01:27 PM
Del70
June 13th, 2011 03:41 AM
Quick Reply: 1971 Cutlass Brake Pedal sticks slighty
