1967 delta 88 holiday sedan
![Question](https://classicoldsmobile.com/forums/images/icons/icon5.gif)
looking for front brake parts for 1967 delta 88 holiday sedan
Looking for a pivot. (the small part between the override spring ant the adjusting link on the adjuster lever). It got lost in the plating process. It is very small. Drum Brakes.
Last edited by PJRiter; September 9th, 2021 at 06:04 AM. Reason: specific parts needed (specificity)
You might get a more useful response with a more specific question. Drum or disc? And WHICH "brake parts"?
Drum brake hardware kits and wheel cylinders are readily available. Correct shoes and drums, not so much. Talk to Craig at Mobileparts.
