1967 Cutlass Supreme Disc Conv Front
I am looking to install a disc conversion for my 67 CS.
1. Recommendations on brand? I would like to purchase a kit that also replaces the master cylinder.
2. Does this effect wheel fitment? If I purchase wheels to fit my current drum setup, will my wheels still fit the new disc setup?
Thanks,
Jim
Thanks,
Jim
Check out The Right Stuff Detailing at getdiscbrakes.com
They have a couple of choices for your car, one of which will work with 14" wheels.
If you're buying aftermarket wheels, pretty much all modern wheels will work with disc or drum brakes.
Any 68-72 GM A body disc set up will bolt straight on to your 67. Chevelle, Monte Carlo, Skylark, Cutlass/442. If you can find it, theres still some out there in bone yards. Theres also a lot of aftermarket pieces too as Copper128 said "The Right Stuff Detailing" has a lot of nice things.
Here's more info.
This picture might help illustrate the difference. This is a 14" disk brake wheel with the stock 10.75" rotors. Note how the backside of the outer rim is shaped to just clear the caliper. The red dashed lines show the contour of a drum brake wheel, where the center drop of the rim was made wider to make tire mounting easier.
As for aftermarket brake kits, the ones that EXACTLY duplicate stock 10.75" rotors, brackets, and calipers should clear any 15" wheel. Kits with larger calipers or rotors can vary. Even some aftermarket kits with stock size rotors use caliper brackets with some differences from stock, which has caused problems documented in this forum in the past.
Disc brake parts
Thanks,
Jim
Thanks,
Jim
I have a used, factory front disc brake set-up with rotors, calipers and spindles. I bought it to convert my drums to disc and then decided to upgrade to 12" rotors and 17" aftermarket rims. It's been sitting in my shop for about 2 years now. I'd just like to get back what I paid for them - $150 plus the ride (as they say). I also have a set of brand new rotors from ILT, same deal, just want to get what I paid for them - $149 plus the ride.
PM me if you're interested.
Rodney
Thats a decent deal- Be aware that you'll still need a new disk/drum master cylinder & disk/drum proportioning valve, and will likely need to make up new brake hardline splices to connect up the old with the new.
I used ECI brake kit on 65 it uses all stock type full size parts (no down sized G model stuff like lots of kits) and it doesn't push the front wheels out wider like most kits. You do have to make your own brake lines but you can get everything else you need from them. Nice people there very helpful. 15" wheels fit fine.
disc conversion
Hey:
Stick w/ a setup that uses some type of OEM calipers/bracket and hardware. I did the complete OPGI conversion kit on my 66 Cutlass and had plenty of brakes on the high horsepower car and had no problems getting OEM style wheels to fit, life will be much easier. There are any number of CO members that help w/ original stuff if that is the direction you want to go.
Thanks Ron
Thanks Ron
yeahbuddy
February 12th, 2014 08:14 PM
Creativeindy
October 29th, 2012 09:13 PM
Flgaurban06
Cars Wanted
September 21st, 2012 07:36 AM
oldzy
December 17th, 2010 05:37 PM
