1950 Super 88 Master Cylinder HELP!!!!
Old Apr 15, 2009 | 08:16 AM
Kensey's Avatar
Hi all, been lurking in the shadows for some time. Finally joined! I recently got my first olds, it's a super 88 holiday long roof. Pretty much ready to enjoy, but I wanted to replace the entire breaking system. So I'm half way through and want a new master cylinder. THERE'S MY PROBLEM! Seems that no one on earth has them? I did find someone local to rebuild the entire thing for around $300. It's got power breaks, so the master cylinder and power booster seem to be one piece?
Would LOVE any suggestions or past stories so I do this right.
Thanks all for your help.
Kensey
Pennsylvania
Old Apr 15, 2009 | 08:17 AM
Kensey's Avatar
1959 NOT 1950!!!
Yep, my first post and I screwed it up. My 88 is a 1959, not 1950. Thanks!
Old Apr 15, 2009 | 08:45 AM
Oldsmaniac's Avatar
Have you tried Fusick or Kanter. The cylinder unbolts from the booster...I thing there are 2 types...Bendix and Moraine....you have to be sure of what you have.
Old Apr 15, 2009 | 01:37 PM
Kensey's Avatar
Answer Found
I have found several people that rebuild the Treadle Vac unit. Thanks for you help.
Old Apr 19, 2009 | 12:40 PM
Samson's Avatar
Brake system
yeah, I had a hard time finding someone to rebuild the treadle vac system on my '58 88... cost me about $300 when I did. found rebuild kits for cheap, but WHO has the proper tools to do that?!
anyway make sure you clean out or replace lines and I recommend strongly, if you haven't done already, replacing the wheel cylinders (if you can find those...) and there is apparently a difference between front and back cylinders [maybe different on '59 models]. ... course maybe you know all this already....
Old Apr 20, 2009 | 05:47 AM
Kensey's Avatar
Thanks for the thoughts. I'm going to have it rebuilt, I'd do it myself but I don't want to die if I do it wrong. Replaced every break component! Rear wheel cylinders are a dime a dozen, fronts were harder to find but I did.
Old Apr 20, 2009 | 06:14 AM
Samson's Avatar
Another option for the brake Master Cylinder is to convert over to a dual cylinder [ more modern Master Cylinder]. some advantages; less expensive and easier to find (can usually just get from local auto supply), and can adjust brake force from rear to front [however, May require a proportioning valve...] for supposed better stopping power or better braking control.
unless you are trying to keep car all original.
bobb
Brakes/Hydraulic Systems
19
Dec 26, 2017 05:59 PM
virtualwsp
Jun 13, 2012 02:00 PM
bobb
24
Feb 24, 2011 07:59 PM
bobb
Sep 24, 2010 03:54 AM
AndyBee
Jul 17, 2010 09:52 AM
