12" C4 Vette brakes on '72 Cutlass
Old Sep 5, 2013 | 02:54 PM
cdrod's Avatar
Rodney
I want to install 12" rotors and PBR calipers on all 4 corners of my 72 Cutlass; parts will come from an '89 C4 corvette. I'm installing 17" AmRacing VN500 rims (they look like Olds SSIs) so rotor clearance won't be an issue. The Vette came with a 7/8" mstr cylinder and the Cutlass has a 1-1/8" mstr cylinder. My biggest concerns (other than whether or not it will stop) are excessive pedal travel and getting enough brake line pressure to stop safely.
I can use a 1" mstr cylinder from a '75 Vette (disc/disc) and use a disc/disc proportioning valve from a '79 WS6 TransAm to properly set the front-to-rear brake bias. The 1" MC has 31% more piston area than the 7/8" MC from the C4 Vette; which means 31% more fluid volume and the pedal will travel 31% less, applying the brakes at a higher point of pedal travel. But with the stock a-body brake booster the brake line pressure will be about 20% less than the C4 Vette brake system.
If I move the booster push rod to the upper hole (typically used for manual brakes) the pedal will travel 8% further (applying the brakes at a lower point of pedal travel) but the line pressure will be 26% higher than the C4 Vette system.
Which approach is the better one? I really hate doing things twice so I'm trying to do as much homework upfront before assembling the parts and making the swap. I'm looking for constructive criticism and feedback. I look forward to everyone's comments.
Thanks!
cdrod
Brakes/Hydraulic Systems
23
Oct 3, 2013 08:57 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
tj78_
Cars Wanted
Aug 2, 2011 11:46 AM
vettemad
Mar 21, 2010 04:41 PM
