1971 rear package tray
That part will have to be replaced with a part from a donor vehicle if it's too badly rusted. It's welded in place and there isn't goint to be any repros on that part. Mine was bad so I had to replace mine.
If its not real bad you can try to sandblast it and epoxy prime it but I blasted mine and there was holes in it. I found a nicer one that had some pits in it and I blasted and primed that one before I cut out the old one and welded the new one in
Also added a video.
http://www.youtube.com/watch?v=za6oe2tdnXM
is their a difference between the Cutlass S and the Cutlass Supreme package tray fitment? Reason I ask is because i seen a couple on line that have different type of slots at each end. mine are oval and at an angle, the S model seems to have them straight back.
; i am located in Abilene, TX. Dont know what shipping on that would be. Ill am shooting to get back in the shop with weekend. I will try to pull the glass and take the areas down to metal to see the extend of the damage.
hurst68olds
Feb 4, 2011 07:40 AM
