1971 rear package tray
Old Apr 4, 2011 | 08:50 PM
mrgm's Avatar
the portion below the rear window is rusted bad, need replacement or patch. The previouse owner ripped the top off and did not pay any attension to the gap at window when removed. So the quesiton is, can i buy a new one, or will i have to make one.
Old Apr 5, 2011 | 03:59 AM
442_Mustang's Avatar
That part will have to be replaced with a part from a donor vehicle if it's too badly rusted. It's welded in place and there isn't goint to be any repros on that part. Mine was bad so I had to replace mine.
Old Apr 5, 2011 | 12:30 PM
mrgm's Avatar
well damn that sucks. Guess i have more hunting to do. Will take out back glass to see how bad it is, if i can repair it then that will be the beezzz knees
Old Apr 5, 2011 | 05:17 PM
If its not real bad you can try to sandblast it and epoxy prime it but I blasted mine and there was holes in it. I found a nicer one that had some pits in it and I blasted and primed that one before I cut out the old one and welded the new one in
Old Apr 5, 2011 | 08:15 PM
mrgm's Avatar
Will have to wait till this weekend to pull glass, if i am lucky. think I will need to start looking for donor because i have a couple of holes that are on the outside where the top was. If they end up being small holes, those i can patch with no problem. crossing fingers
Old Apr 6, 2011 | 11:12 PM
UnkleMarc455's Avatar
GM's Best Division
I got the same problem with mine but its been ripped out already but its in the trunk. Guess its out to the yard again! maybe I can get on tv - Desert Valley Auto Parts!
Old Apr 7, 2011 | 02:21 PM
mrgm's Avatar
will keep an eye out for you on the tely.
Also added a video.
http://www.youtube.com/watch?v=za6oe2tdnXM
Old Apr 10, 2011 | 06:08 AM
mrgm's Avatar
is their a difference between the Cutlass S and the Cutlass Supreme package tray fitment? Reason I ask is because i seen a couple on line that have different type of slots at each end. mine are oval and at an angle, the S model seems to have them straight back.
Old May 11, 2011 | 10:35 PM
GM's Best Division
The Cutlass S is going to be the 442 body style and there package tray area is a lot bigger, not sure about the strip at the very back under the window though.
Old May 12, 2011 | 01:08 PM
mrgm's Avatar
Thanks for that info...guess i have to find one specific to supreme.
Old May 12, 2011 | 03:17 PM
oldspackrat's Avatar
I just bought two more '72 Supreme parts cars today, I might be able to help you out. I'm in Indianapolis, where are you?
Old May 12, 2011 | 03:47 PM
mrgm's Avatar
that would be great ; i am located in Abilene, TX. Dont know what shipping on that would be. Ill am shooting to get back in the shop with weekend. I will try to pull the glass and take the areas down to metal to see the extend of the damage.
2blu442
May 19, 2012 01:53 PM
70cutt
Nov 12, 2011 05:00 PM
hurst68olds
Feb 4, 2011 07:40 AM
big mean
Jun 12, 2010 07:27 AM
Ranzan
Apr 30, 2010 04:34 PM
