72 Supreme Convertible cowl windshield channel repair
Old Dec 27, 2024 | 06:35 PM
flameorange's Avatar
Newbie pulling body off frame, and addressing all rust on my 72 Supreme Convertible I have owned since 1982.
Removed my windshield to address upper windshield brace bubbling.
Good news is windshield came out in 1 piece, bad news is it came out easily because bottom cowl windshield channel under the stainless trim has completely disappeared!😕😫
1. Has anyone got any pics of what the lower windshield channel SHOULD look like if it isnt rotted away? Seems like that lower stainless trim is a real rust catcher…
2. There seem to be 2 patch repair panels available, I have ordered those. The metal piece on the dash between the padded dash and the cowl grill area, is that reproduced or do I have to find a used one? See pic, red arrow.
Thanks folks, Happy Holidays, and thanks for your help!
Old Dec 27, 2024 | 07:29 PM
OLdGreenPaint's Avatar
Must be the season for rusty 72 verts. I’ll follow your work!
Old Dec 27, 2024 | 08:14 PM
likewise! Im putting a new frame under it….
Old Jan 1, 2025 | 11:02 AM
Interesting Shop you have there! When the newest vehicle is a 72 Olds.
Old Jan 4, 2025 | 04:51 AM
Crankit's Avatar
Hey flame??? That looks so familiar did it to my 72 convert along with a pillars and almost the whole cowl area I dont think they make a new dash peice from the pad outward..but the windsheild peice will cover that up I measured mine ,cut it and fit it about 100 times!! Cant remember if the cowl peice goes under or over the windsheild channel I will send some pics ...remember must be extremely flat or windsheild can crack or leak..good luck..crankit
Old Jan 4, 2025 | 08:33 AM
Crankit's Avatar
inner cowl was somewhat ok
top panel shot.and windsheild peice
lower cowl ok
lower cowl ok
windsheild and cowl welded in lots of cutting and grinding
Old Jan 6, 2025 | 10:14 AM
Great pics thanks!
Fantastic pics thanks!
Exactly what I have to do…..
Where did you buy the top repair piece, what brand?
lower cowl ok
lower cowl ok
Old Jan 6, 2025 | 10:50 AM
Crankit's Avatar
Iam pretty sure the top cowl peice was from opgi...the windshield peice I dont recall but at the time they didnt make one for 72...so I think it's a chevelle ...little trimming and the bow is right fit pretty good..I wanna say they make one for cutlass now someone on here will know..it only covers so much of the dash I had to weld in a strip 2 inch wide strip to accont for the rotten dash just under the vin tag... crankit
Old Jan 8, 2025 | 03:31 PM
Thanks great info.. I havent found a Cutlass version only the Chevelle version AMD.
cheers, going to do same effort you did 💪
Old Jan 8, 2025 | 03:53 PM
Crankit's Avatar
I think that is the one sounds familiar...just go slow ...measure measure measure...use witness mark so it goes back exactly each time you trim and dont weld in fully until the very very end and weld or tig slowly to prevent warpage...clecos...work great for this application...good luck...any problems shoot a text might be able to give some insight....crankit..
Old Jan 9, 2025 | 01:13 PM
Perfect
Thanks for the help will keep you posted.
likely not until end Feb before we get to that…
Happy New Year ✌️
Old Jan 10, 2025 | 03:39 PM
alain's Avatar
Try the partsplaceinc went with them and all the parts were very good for one of my W-31 restorations
You will need both pieces and a very experience body man
Alain
1970 platinum 442 4spd factory A/C
Old Jan 10, 2025 | 04:32 PM
Crankit's Avatar
Thanks alain....hopefully flame see this post...iam thinking the part is the same from diffrent companies but hey maybe not...chevelle cutlass abodyies...??? Thx...crankit
Old Jan 11, 2025 | 06:57 AM
I see it
checking partsplace thanks ✌️
Old Jan 11, 2025 | 09:53 AM
Crankit's Avatar
Hey flame check the number on chevelle and cutlass I believe they are the same. ...so chevelle cutlass same part number maybe diff price???? Crankit...
flameorange
Body work
Dec 16, 2024 04:14 AM
Chuxter
Body work
Jun 29, 2023 08:56 PM
bry593
Body work
Nov 4, 2021 05:59 AM
83hurstguy
Jun 13, 2020 06:06 AM
dallasite21
Aug 13, 2012 02:34 PM
