Trunk Lid depth
Old Dec 21, 2021 | 02:28 PM
tkcutlass's Avatar
Trunk Lid depth
Is there a way to get the trunk lid to set lower into the cavity, shims somehwere perhaps?
There was a ton of bondo on the filler panel perhaps that needs to be pushed up.
Old Dec 21, 2021 | 02:48 PM
tnswt's Avatar
'70 4-Speed W Machine
If I'm viewing your photo correctly and it looks like the deck lid is higher toward the rear glass opening. You would place the appropriate shim under the deck lid hinge bolt closest to the rear of the automobile on the side that is high. That will force the end of the deck lid closest to the rear window opening down. When doing this be certain to loosen both hinge bolts, insert the shim and then tighten both bolts once alighment is complete. This is better accomplished with 4 hands.
With a shim the appropriate thickenss this should give you want you want.
Happy Motoring!
Old Dec 21, 2021 | 03:12 PM
tkcutlass's Avatar
Awesome that's the info I was looking for.
https://www.opgi.com/sheet-metal-bod...y-ch27366.html
Hmm
not cheap
Old Dec 21, 2021 | 04:04 PM
RetroRanger's Avatar
72 Olds CS
Amazon Amazon
ive found the dorman shims in the help section at the local auto parts store
Old Dec 21, 2021 | 05:16 PM
tnswt's Avatar
If you are looking for an inexpensive body shim they can be found at HF.
Old Dec 22, 2021 | 08:46 PM
tkcutlass's Avatar
Thanks, stopped by HF and picked up some shims.
I am Amazed with the difference
Old Dec 23, 2021 | 04:47 AM
mattking's Avatar
I was going to say the same thing about the HF shims.... and you are correct... wow what a difference it made
Old Dec 23, 2021 | 06:06 AM
tnswt's Avatar
You had great success with the deck lid!
Old Dec 23, 2021 | 07:58 AM
tkcutlass's Avatar
I was surprised how thin of shim was required. 1/16 on the driver's side and 1/32 on the passenger side is all it took.
bigdooly
Aug 14, 2019 03:55 PM
Zr1bandit
Mar 5, 2017 09:33 AM
russ0326
Dec 18, 2013 07:45 PM
droptopcad
Jan 16, 2011 06:30 AM
dartson70
Feb 1, 2009 06:43 AM
