Driver fender
Old Dec 10, 2021 | 05:10 PM
J1978's Avatar
Driver fender
Hi wondering if this type of damage can be fixed or not. And if anyone has a fender for sale? Thanks! 1978 delta 88.
it’s dented what seems to be lighter damage compared to the bottom of the fender. And I can’t open the door all the way it opens slightly. Thanks. J
Old Dec 10, 2021 | 05:27 PM
F-85 4-4-2's Avatar
Anything can be repaired, but that looks pretty far gone. I can't tell your location, and whether you have cornering lights, but either way, there are at least seven (7) fenders on Car-Part.com--Used Auto Parts Market, and a few are dark blue. One of those was $65.
Old Dec 10, 2021 | 06:05 PM
J1978's Avatar
I’ll take a look thanks!
Old Dec 11, 2021 | 04:05 AM
Yeah that whole fender looks jacked, not only the lower part. It can be repaired but I would replace it unless you cant get a good clean one. Too bad that happened, but it can be fixed. Keep us posted!
Old Dec 11, 2021 | 06:56 AM
The dent at the bottom is easy. Pulling the entire fender back into position is more difficult. The reality is that this is just mild steel. It can be straightened and any tears welded easily. The problem is pulling in the correct direction. The fender needs to be pulled in the direction opposite from the original impact to pull the inner mounting tabs back into position. Do not attempt to do any local straightening until you do that first. And be aware that there is probably distortion on the cowl and core support where the fender attaches, which is why it's pushed up and out of position. That damage needs to be pulled back into position even it you get a replacement fender, or the new one won't fit correctly. This is where a shop that knows how to use a frame machine can be invaluable in pulling the damage back to where the parts need to be.
Old Dec 11, 2021 | 07:15 AM
RetroRanger's Avatar
72 Olds CS
With some time and effort You can easily pull it off and repair it good enough to look ok and allow your door to open.
if your looking to make it nice, good gaps etc, it will be easier w a good fender. The hardest part may be finding a nice fender.
Old Dec 12, 2021 | 05:05 AM
scrappie's Avatar
Some dents and even tears like others have said can be fixed. The challenge is when the metal gets stretched. Its very hard if not impossible to shrink the metal back to its original state. Will be much easier to replace IMO.
ssbigken
Nov 15, 2022 10:29 AM
Jim Miller
Nov 26, 2020 09:39 AM
wills30
Apr 14, 2018 01:06 PM
rcdynamic88
Jan 4, 2017 02:10 PM
allyolds68
Jan 13, 2016 10:59 AM
