Seam Sealer
Seam Sealer
Is there a diagram anywhere which shows which areas get seam sealed? I have a 1972 Supreme that has been blasted and want to make sure I get the right areas. I should have documented the locations before blasting.
seam sealer is a waterproof flexible coating usually put where two pieces of sheet metal have been joined together.
as an example on the cowl where several parts or welded togther you seal the seam w the seam sealer to prevent corrosion and water intrusion.
