Seam Sealer
Old Aug 17, 2021 | 08:18 AM
ajr2820's Avatar
Seam Sealer
Is there a diagram anywhere which shows which areas get seam sealed? I have a 1972 Supreme that has been blasted and want to make sure I get the right areas. I should have documented the locations before blasting.
Old Aug 23, 2021 | 08:54 AM
ajr2820's Avatar
Nothing?
Old Aug 25, 2021 | 08:30 AM
Dans72's Avatar
Sorry I'm not familiar with seem sealed what is that? On the frame? Welding?
Old Aug 27, 2021 | 06:23 PM
RetroRanger's Avatar
72 Olds CS
seam sealer is a waterproof flexible coating usually put where two pieces of sheet metal have been joined together.
as an example on the cowl where several parts or welded togther you seal the seam w the seam sealer to prevent corrosion and water intrusion.
Old Aug 27, 2021 | 07:29 PM
Dans72's Avatar
Oh OK cool, I had no idea
Josh Pawnell
Dec 23, 2018 11:30 AM
72Supreme4Speed
Aug 21, 2018 11:00 AM
MyBlue72
Mar 6, 2018 07:03 PM
virtualwsp
Apr 4, 2014 12:03 PM
72GOTTA
May 4, 2008 04:17 PM
