Template question...
Old Sep 26, 2019 | 10:41 AM
72455's Avatar
1972 U code Supreme
Is there a template available for the trunk lettering on a '72 Supreme? Thinking about putting them on mine, and if I'm gonna drill holes, I need them to be right.
Old Sep 26, 2019 | 10:46 AM
Dave, a lot of people have asked that question. I think there's a thread somewhere on CO about it. Your car is a 72 isn't it? They came standard with letters on the decklid.
Old Sep 26, 2019 | 12:09 PM
72455's Avatar
1972 U code Supreme
Yesssir...'72, but a PO removed the letters.
Old Sep 26, 2019 | 12:52 PM
69HO43's Avatar
Can you just clip off the studs and double sticky 3M tape them on? Won't have to jack around with drilling holes. One mess up with drilling and you'd be filling and doing it over. Plus repainting the trunklid. Depends on if you are going for 100 point restoration or not.
Old Sep 26, 2019 | 02:21 PM
If a PO removed the letters, chances are the holes are welded or filled with body filler. I like the idea ^^^. That's what I'd do, and it's really easy to position letters with tape before taking off the backing from molding tape. Either that or just leave the letters off. Do you have the letters or just thinking about getting them?
I have a set of letters that I'm going to use on a promo board for my car when I'm at car shows.
Old Sep 26, 2019 | 04:35 PM
I am not seeing how you would use tape without trimming it around the contours of each letter. I think I'd try drilling holes before attempting that!
Years ago I made a template off an old deck lid using butcher paper and shading the deck lid edges and the letter holes with a pencil. Even with that homemade template, I never got the courage to try and precisely drill 20 holes so the letters would be perfectly aligned. Just one hole off a bit and it would look like crap.
Old Sep 26, 2019 | 05:22 PM
72455's Avatar
1972 U code Supreme
I thought about clipping off the studs, but if they're the same size as the ones on the fender scripts, and given the size of the letters, it could be a daunting task🤔🙄😲
Old Sep 26, 2019 | 05:25 PM
72455's Avatar
1972 U code Supreme
Trust me, 3M tape isn't the most forgiving when it comes to trimming...very cumbersome, so I'm with you on that. If anything, I'll use the adhesive I used on my fender scripts.
Old Sep 26, 2019 | 05:27 PM
72455's Avatar
1972 U code Supreme
I don't have the letters yet Allan...was just kicking around the idea and getting some feedback on the easiest and most efficient way.
Old Sep 26, 2019 | 06:24 PM
Kenneth, that's exactly why cutting the posts off and using body tape would be the best approach. I looked and can't find anywhere that shows the drill locations. A good sharp exacto knife with thin body tape is surprisingly easy to use.
Old Sep 26, 2019 | 06:25 PM
Dave, the studs on those letters is actually quite small and thin.
Old Sep 26, 2019 | 07:46 PM
As I said, I have a template for the drill locations but I haven't attempted to use it in nearly 25 years for the reasons stated previously.
Just my opinion, but I do no think trimming double sticky tape to follow the outer and inner contours of the letters would be an easy operation. I have not tried it, so I may be wrong about how easy it is.
If I did it, they would likely end up as jumbled as these:
Grimmjow Jaegerjaquez
Feb 14, 2019 11:00 AM
79 TRANS AM
Nov 25, 2011 12:57 PM
B-Mann
Jul 4, 2011 07:01 AM
#1CutlassSupreme
Jun 11, 2008 01:31 PM
72Cutlass
Mar 31, 2008 10:53 AM
