Vinyl replacement
Old June 10th, 2017, 05:42 PM
Manny88's Avatar
Vinyl replacement
Hello my first time trying this i'm trying to surprise my husband with info on how to do it your self vinyl replacement he has a 87 oldsmoble cutlass brougham 2 door he is soon going to get it painted but must get the vinyl top replacement and i called around and people want like 700 dollars to do it and that is to much for our pocket any guidance would be truly appreciate.
Manny88 is offline
Old June 10th, 2017, 07:31 PM
Olds Fever
CRUZN 66's Avatar
Welcome to the site... First and foremost, removing and replacing a vinyl top is not an easy task for many individuals... Since the plan is to repaint the vehicle, a suggestion would be to remove the top completely and paint the entire roof... You will need to obtain the non-vinyl top trim and side windows, but those are not difficult to find... Here is a link to removing the top to give you an idea of the work involved in just removing it.... The reinstall would be more tedious and time consuming...
CRUZN 66 is offline
Old June 11th, 2017, 06:50 AM
I assure you the $700 is well spent to replace a vinyl top. Its a royal pain in the butt and if not done correctly will create major headaches down the road. So if he is not really handy, patient, or thorough, instead of surprising him with instructions surprise him with a top.
oldcutlass is online now
Old June 14th, 2017, 03:27 AM
chopolds's Avatar
In my experience, in NJ, when you remove a vinyl top, there is usually extensive rust underneath it. This has to be repaired first, and correctly, before even thinking about putting the vinyl on. Most customers opt to just do the repairs and paint it, instead of having the extra expense of the vinyl install, on top of the repair/paint.
Just a warning, unless you live in a very dry climate.
chopolds is offline
70Post
November 10th, 2022 09:30 AM
Cutlass71s
Body work
April 16th, 2016 02:39 AM
Georgek117
November 17th, 2014 04:54 PM
hinz57
August 10th, 2010 08:16 PM
Cuttyon22s
August 8th, 2006 01:12 PM
Quick Reply: Vinyl replacement
