Windshield trim fitment issues
Old Feb 25, 2024 | 02:07 PM
72455's Avatar
1972 U code Supreme
I noticed today that I have these gaps between my windshield trim and the windshield on my '72 Supreme. I just had the vinyl tip replaced and I gave the shop (what I thought) were the right clips.
This is the set that I gave them and according to Fusick, these are the correct ones for the windshield. The ones at the bottom of the pic are the ones they used, but I'm wondering if they should have used the other ones.
If the ones they used are correct, then how can I close the gap between the trim and the windshield? Is the problem caused by the vinyl that runs along the a pillar not allowing the clips to slide down far enough to pull the trim closer to the windshield?
Old Feb 25, 2024 | 03:15 PM
Carlarena1's Avatar
I'm sure someone with more knowledge of this will chime in, but i had something similar happen on a 79 Chevy van, though the gap was less severe. I had the windshield re- installed because the butyl seal had failed. When they reinstalled it, they used a liquid sealant of some kind and as a result didn't have the height of the butyl strip when installed. The seal was great, and it didn't leak, but there was a gap right where you have a gap. Hopefully this helps!
Old Feb 25, 2024 | 03:16 PM
72455's Avatar
1972 U code Supreme
Thanks for the reply, but the windshield wasn't removed when the top was replaced.
Old Feb 25, 2024 | 03:55 PM
70Post's Avatar
Can't tell 100% from your pics but it almost looks like the surface of the windshield is also well below the stainless trim that runs across the top of your windshield. If so, then maybe the windshield was replaced at some point using too thin of a urethane bead or too small (OD) of a butyl tape roll.
Also....many replacement windshields, if not all, are thinner than the original windshields.
You mention the vinyl top material and the clips.....is the vinyl UNDER the bottom edge of those trim clips??? If so, then that may have added some height to the trim placement.
Old Feb 25, 2024 | 04:04 PM
70Post's Avatar
Also - I just checked the "windshield height/depth" on an original '70 car.....original windshield/glass that's never been removed, reset, etc.
The height of the windshield face surface seems to be at least 1/2" above the flat metal surface down in the channel. It seems to be ever-so-slightly taller in certain areas (a 32nd or two taller). I avoided any area that had the original windshield sealant blocking the depth caliper tip from the painted metal channel surface. Not a super scientific measurement but maybe some info to give you something to compare to.
Has your windshield been replaced sometime in the past??? The logo etched into the windshield may hold the clue to that question. Could be a combo of a newer/slightly thinner replacement windshield in the past and too thin of a butyl tape or urethane sealant bead.
What was done on the back glass? (new clips, etc??)
Old Feb 25, 2024 | 05:47 PM
72455's Avatar
1972 U code Supreme
If you look real close at this pic, it appears that the glass is above the area you mentioned above. As far as the back glass, it wasn't removed for the job.
Old Feb 25, 2024 | 05:49 PM
72455's Avatar
1972 U code Supreme
Yes, the vinyl is down inside these channels.
Old Feb 25, 2024 | 06:38 PM
So how was it before the new vinyl top was installed? Did you compare the new trim clips to an old one to verify they’re the same?
Old Feb 25, 2024 | 06:43 PM
72455's Avatar
1972 U code Supreme
I didn't...I just gave them the set of new clips that I bought, and I still dunno which clips are for the "a" pillar trim...any idea?
Old Feb 25, 2024 | 07:09 PM
70Post's Avatar
Sorry - It's not clear to me what you're referring to in your reply that I quoted.
On your next reply you really didn't answer one of my questions which is whether or not the vinyl top material is UNDER the BOTTOM EDGES of the trim clips. I'm not talking about whether the vinyl is BEHIND the clips....but instead asking if it's UNDER the bottom edge of the clips.
Old Feb 25, 2024 | 07:27 PM
72455's Avatar
1972 U code Supreme
Sorry - It's not clear to me what you're referring to....nor is your next reply to me about the vinyl (you show a pic but there's no vinyl in the pic, etc.).
Sorry for the confusion. You are correct...there is no vinyl because that pic was taken before the new top was installed. I only used it for reference to highlight the area in question as to whether the vinyl was supposed to run along that channel, and maybe that's why the clips aren't going down far enough.
And the other pic was to show that it looks like the glass is where it should be.
Old Feb 25, 2024 | 07:30 PM
70Post's Avatar
I also asked.....has the windshield ever been replaced? No answer.
In your last reply again, not sure what you're referring to....maybe the open GAP between the edges of the windshield and the surrounding Apillar and roof metal?
If so, that's not what I was talking about when I mentioned the 1/2" HEIGHT that I measured. Seems like you may be referring to the GAP around the windshield....which has ZERO effect on how your stainless fits.
Old Feb 25, 2024 | 07:42 PM
72455's Avatar
1972 U code Supreme
I'll take some better pictures and post them as soon as I can. Also will let you know if the glass has ever been replaced.
Old Feb 25, 2024 | 09:05 PM
Also wondering about this.
Old Feb 26, 2024 | 02:05 AM
72455's Avatar
1972 U code Supreme
From what I can remember, it was good. Maybe a small gap towards the top, but nothing serious.
Old Feb 26, 2024 | 05:57 AM
Is this an OEM windshield or a replacement? The aftermarket windshields are thinner than OEM.
I'm having trouble following the order of replacement here. Factory used urethane sealer/adhesive in a caulking tube. The factory installation process uses spacer blocks on the glass to set the height of the glass and to center it in the opening. If the windshield is to be replaced, there are two ways to do this in the Fisher Body Manual, cutting the existing urethane and using a thinner layer of new on top of that or removing it completely and using the original factory method. Butyl tape is an alternate that was not used by the factory, but I've used it with success. Be aware that butyl tape comes in different diameters, so you have to use the correct thickness. If the shop did use urethane from a tube, did they get the thickness correct when they set the glass? If not, you'll get a gap.
Old Feb 26, 2024 | 06:43 AM
72455's Avatar
1972 U code Supreme
Joe, the shop didn't R&R the glass. Whether it was done in the past, Ill have to look into that. I do know the gap wasn't as bad before I had the vinyl replaced. It's a little hard to tell in this pic, but you can see what I mean.
Also, I still don't have a definitive answer on what clips are correct.
And finally, is the vinyl supposed to be down inside the "a" pillar channel? I ask because maybe the vinyl isn't allowing the clips to go down far enough to pull the trim closer to the windshield.
Old Feb 26, 2024 | 12:18 PM
72455's Avatar
1972 U code Supreme
I just some "in progress" pictures from the shop when they were doing the work, and it would seem my hunch about the vinyl not allowing the clips to go down far enough for the trim to fit closer to the windshield would be on point.
If you look at this picture, you'll see that before, the vinyl actually went "around" the clips. This would explain why the trim fit better.
Old Feb 26, 2024 | 01:15 PM
70Post's Avatar
You should be able to remove one of the A-pillar stainless trim pieces and get a better/closeup look at the clips.
See if the "nailhead" studs the clips slip over are fully up in the slot of the clips and/or see if the clips look to be bottomed out on vinyl or body metal. It may take some real closeup inspection and a good light.
Another question I have is how flush the outer edges of the stainless are with the adjacent roof and vinyl-covered A-pillar metal.
Still wondering if the w/shield is original or not.
Old Mar 3, 2024 | 04:41 PM
72455's Avatar
1972 U code Supreme
I came up with a solution. Since I couldn't close the gap, I filled it in with some weather stripping.
Old Mar 4, 2024 | 05:05 AM
Oldsguy's Avatar
Past Administrator
That looks pretty good. I think the solution you came up with was the best you could do, congrats on not giving up.
Old Mar 4, 2024 | 09:27 AM
Dave - Ya dun good.
Old Mar 5, 2024 | 02:09 AM
BackInTheGame's Avatar
I'm surprised the shop let it out the door that way without checking with you.
DFitz
Dec 12, 2015 09:59 PM
oddball
Body work
Jun 1, 2015 06:32 AM
Leroy701
Sep 5, 2014 03:31 AM
bigbrother
May 23, 2008 05:22 AM
cutlassfan
Apr 2, 2008 10:56 PM
