windshield channel and a pillar rust
Old Sep 27, 2015 | 07:32 PM
Krom's Avatar
couple questions on trying to fix/find parts to fix the rust around my 72 cutlass S windshield.
I've found this:
I'm assuming that this is between the dash and the cowl
Next question, do chevelle a pillars work?
The car needs a roof skin, and it looks like that includes the top of the ws frame. what is the piece of structure called that doubles the roof skin along the top of the ws opening.
Has anyone used dynacorn parts before? they are selling a complete chevelle body so I was hoping that many of the parts I need are the same.
Old Sep 29, 2015 | 04:52 PM
68442's Avatar
The part you show will not work on a cutlass. No one is making the upper dash piece for cutlass's. The A pillar on a chevelle will work for you. Chevelle roof skin is different. But if you only need the front edge that portion is the same, you could use only what you need?? I do believe they make a repro cutlass roof skin however.
Old Sep 29, 2015 | 05:40 PM
oldspackrat's Avatar
I have a pretty nice lower front windshield channel from a '72 Cutlass S. It has some surface rust & a couple pin holes but it is a lot less expensive than the incorrect repro pieces. I might have a good roof skin also but will have to check.
Old Sep 30, 2015 | 04:26 PM
Krom's Avatar
I'll be cutting the roof off soon, and getting the shell media blasted. I will pm you with a list of parts if thats ok
Old Sep 30, 2015 | 04:38 PM
Pm or even better, call me?
Thanks,
Scott
c. 317-727-7041
rcktdoc
Mar 20, 2014 03:58 AM
Autobahnzerreisser
Body work
25
Mar 18, 2014 01:07 PM
oldspackrat
Jan 20, 2014 05:17 PM
my442conv
May 19, 2012 04:03 AM
Bluevista
Apr 22, 2008 05:33 AM
