Upper Windshield Trim Removal
Old Mar 23, 2012 | 12:45 PM
starfire's Avatar
OK, I'm trying to remove my upper windshield trim piece (see pic below, black arrows are pointing to it).
The lower and sides came of perfectly, although there were no clips for the sides and my body book says there should have been. I've been all along the area between the windshield and the trim piece with this tool:
and I am not running into the clips that my body book says holds it in. Are there really supposed to be clips? Does anyone have a pic showing what they look like and/or how they work? The body book is no help with that. Can anyone here help me with this? I'm starting to suspect a previous owner glued the trim piece in.
Old Mar 23, 2012 | 12:59 PM
mrolds69's Avatar
If the car in your pic is the car you are working on, there should be clips, almost right where your arrows are! There should have been clips on the side, too. It's possible someone siliconed or glued it on.
Old Mar 23, 2012 | 01:04 PM
starfire's Avatar
And I should be able to feel those clips when I insert the tool and run it along the windshield, right? In other words, I insert the tool between the trim piece and the windshield and I have one of the tips all the way to the top, as I move the tool all the way across the top of the windshield I should keep running into clips. But I don't. So it does look like the piece has been adhered to the windshield then. Crap. I'll try the heat gun and see if I can loosen up the adhesive. Thanks!
Old Mar 23, 2012 | 01:26 PM
gearheads78's Avatar
car guy
There will be clips but they are hard to see and near impossible to feel. When I get a tough one what works for me is to pry the moulding up just a little and use a paint stick to hold it up just enough. Use a small flashlight and look under the moulding. You will see a bump only about 1/16" into the moulding. Get your tool behind that bump and pry it toward the bottom of the windshield / cowl while applying slight upward pressure on the moulding away from the car. Once you get one or two clips loose the rest come easy.
Old Mar 23, 2012 | 03:04 PM
starfire's Avatar
How the hell does that hold the trim piece on? I would love to see a picture (or even a hand drawn sketch) of what is going on under that trim piece.
Old Mar 23, 2012 | 03:20 PM
car guy
I can try tonight when I get home. I tryed to just draw something but it was going to just confuse you more.
Old Mar 23, 2012 | 03:22 PM
starfire's Avatar
I know that feeling! Thanks, cause I am just not finding them.
Old Mar 23, 2012 | 05:13 PM
car guy
Hope this helps a little.
Old Mar 23, 2012 | 06:45 PM
starfire's Avatar
Thanks Richard. I will have to study those for a while, but that will definitely help me out. I appreciate the time you took.
Old Mar 24, 2012 | 05:41 AM
starfire's Avatar
So are the clips going to pop out, or is the trim piece going to pop off of the clip when I pull the clip down?
It looks to me like the latter as in the pictures it appears that the clip itself is held in place by the windshield.
Old Mar 24, 2012 | 06:44 AM
car guy
This ... the clips stay attached to studs on the body.
Old Mar 24, 2012 | 12:33 PM
starfire's Avatar
Got it!!!!!
Richard, thanks again for the pictures and other help.
oldspackrat
Mar 6, 2018 12:47 PM
HonestDave
May 1, 2013 08:02 AM
dallasite21
Feb 24, 2012 01:34 PM
roady61
Feb 21, 2012 07:44 PM
