Trunk Floor Pan
Old Jun 16, 2017 | 04:09 PM
dream66's Avatar
Cory
Trunk Floor Pan
Ain't classic cars fun?
Old Jun 16, 2017 | 04:11 PM
dream66's Avatar
Cory
But why stop there ???
Old Jun 16, 2017 | 06:32 PM
Gary M's Avatar
Nice work
Bet that took a minute.
Old Jun 16, 2017 | 06:47 PM
Gary M's Avatar
Found this earlier today
dont know if you need one and don't know the seller.
http://m.ebay.com/itm/100-Point-Cars...257Ciid%253A23
Old Jun 16, 2017 | 09:16 PM
dream66's Avatar
Cory
Wow! Who woulda thought you could find an original that nice.
Old Jun 17, 2017 | 05:45 AM
Gary M's Avatar
Looks good in the picture anyway. Who knows what it looks like under the braces and if he cut it high enough at the rear.
I drove to WV to get one that looked good. Things like that you almost have to verify before you buy.
Old Jun 17, 2017 | 06:24 AM
RetroRanger's Avatar
72 Olds CS
Azchevs is a member on here, or at least we have a user w the same name and similar location.
Old Jun 17, 2017 | 06:39 AM
Gary M's Avatar
If he's a member, hope he posts his stuff on here. I know I'm more likely to buy from a member because they build a reputation.
Old Jun 17, 2017 | 06:41 PM
The rear windows on these lead to a lot of other collateral damage. Put drains in the bottom window channel like/similar to the optional stock offering.
Old Jun 18, 2017 | 07:42 AM
dream66's Avatar
Cory
What???? There was actually a factory option for a scupper drain in the channel corners?
I've always been amazed that GM didn't make that standard. Any 12 yr old can look at at a rusted out channel and immediately see that as a solution.
Never made that modification myself though. Anybody have pics of theirs.
Old Jun 18, 2017 | 08:57 AM
They look similar to this. The hoses run through the trunk and pop out the lower rear fender behind the tires. There are a few different styles aftermarket.
Amazon Amazon
Amazon Amazon
Old Jun 22, 2017 | 07:57 PM
dream66's Avatar
Cory
Update Pics (72 Cutlass Supreme)
Got the trunk pan installed and etch primed. Decided to lap the joints vs butt joints and use body filler to smooth out the seams.
The repro pans are Golden Star from Tamraz - best price I could find with free shipping. The fit was very good.
Old Jun 24, 2017 | 02:33 PM
therobski's Avatar
Not only was my trunk gone so were the braces, rear window channel and the section between the tails lights. You did a great job, I should have bought the one piece trunk-live and learn!
Old Jul 4, 2017 | 11:55 AM
dream66's Avatar
Cory
Here's a pic after spatter paint. I used Zolatone 20 series over medium gray primer and sprayed it with a HVLP primer gun using a 2.0 tip (largest I had). The Zolatone TDS recommended 40-50 psi input but I had to crank it up to 70 psi with the fluid adjustment full open.
I think the next time I do a spatter paint job I'll buy or borrow a pressure pot gun. I have a shutz gun for undercoating and bed liners but I was afraid it would be overkill.
Old Jul 16, 2017 | 01:02 PM
dream66's Avatar
Cory
Home made copper tubing drains. Not finished with the install - still need to epoxy seal the scuppers.
EDIT: I used 1/2" copper tubing and over-flared the end. Then contoured the flare with the pick end of a body hammer.
Old Jul 24, 2017 | 04:50 PM
dream66's Avatar
Cory
One more step prior to installing rear window - have to re-do the gray paint line on the lower pinch weld. I mistakingly cheated into the interior lower molding that needs to be black satin or the gray will show through the window.
On the advice of my paint supplier, I used gray direct to metal urethane primer and urethane clearcoated over it - the clear coat to prevent moisture penetration.
I was planning to use epoxy primer but my paint supplier advised otherwise. Go figger.
I'm going to install the window myself using the method and kit described here:
Old Jul 25, 2017 | 07:53 AM
Run to Rund's Avatar
40 years ago, I had the body shop fill the bottom channel with butyl rubber before popping the chrome into place. If water can't get in, you won't need drains.
Old Jul 25, 2017 | 10:51 AM
dream66's Avatar
Cory
That butyl rubber - is it pretty easy to remove if ya need to replace a broken glass?
Old Jul 25, 2017 | 12:11 PM
72 Olds CS
pretty sweet work on the drains. where do they drain to ?
Old Jul 25, 2017 | 04:11 PM
dream66's Avatar
Cory
They drain through a tube routed to the drop down behind the wheel house.
Old Jul 29, 2017 | 07:04 AM
edzolz's Avatar
I was in the home window business for awhile. If the original glass was installed with the butyl, had to cut it out with a knife. Sorta like removing RTV. It is a real bitch to remove.
Old Jul 29, 2017 | 05:07 PM
dream66's Avatar
Cory
Imagine trying to clean that crap out of the pinchweld channel around molding clips and the white vinyl top that has to be peeled back - on a hot Texas afternoon.
Old Aug 4, 2017 | 09:09 PM
Triharder's Avatar
Looks great. I just finished my trunk as well, did the window frame and window to trunk filler a while ago. Time well spent.
Old Aug 12, 2017 | 02:20 PM
dream66's Avatar
Cory
UPDATE:
I didn't buy the kit from the vendor as stated in my above post. Instead - I bought a tube of SIKAFLEX P2G urethane and a Riobi cordless caulking gun and a roll of CR Laurence 1/4 inch foam tape.
The process is fairly straight forward and the back glass went in with out a hitch. NOTE: The self cut triangular shaped cut in the applicator as described in the above video applies about a 1/2" tall triangular shaped bead which allowed us to vary the pressure on the glass at specific points along the uneven pinch weld flange and achieve the proper glass standoff from the channel. Also, we had three areas where the urethane was applied too thick and it squeezed out into the pinch weld channel. After drying it was easy enough to cut away with a razor knife.
One Caveat: The foam tape which we used as a dam only - not as a standoff shim; After removal, leaves a film of sticky adhesive that had to be removed with a single edge blade and wiped down with Goof Off solvent (or similar solvent) which took about 30 minutes. I may shop for a different foam tape system the next time.
I do advise practicing the application of the urethane bead (about 6-12 inches will do it) on a piece of plywood to set the proper speed of the cordless caulking gun. There's plenty of urethane in one tube to do a single backglass or windshield so not to worry about wasting product for practice purposes.
Glad we did it this way since I have 2 more windshields and one more backglass to install...so saved a few coins in the long run.
Riobi Gun - $100/ 4 installs so $25 per glass, plus Sikaflex P2G $10, plus Foam tape $20 = $55 per glass installed
dream66's Avatar
Cory
Installing the the SS molding was a whole nuther story. Many expletives flew around the shop and almost led to flying tools.
We had 3 molding clips that kept falling off the aftermarket screws that replace missing nails. The narrow clips in the pic just wouldn't cooperate. Only after reverting to the wide clips were we able to seat the molding.
jstrits
Feb 7, 2016 11:33 AM
AzChevs
Oct 19, 2014 09:03 PM
AzChevs
Oct 8, 2014 10:13 AM
Hawk1061
Jun 9, 2013 09:02 AM
Olds57rocketgal
Apr 13, 2007 09:17 PM
