Speed Nuts
Old Apr 19, 2023 | 07:50 AM
Carsick's Avatar
Speed Nuts
I'm about to put on the front clip. Which speed nuts do I need for the fender trim(s)?
Old Apr 22, 2023 | 01:37 AM
Carsick's Avatar
I'm thinking the emblems and trim require different size speed nuts. Please help as im about to start this fender!.
Old Apr 22, 2023 | 04:59 AM
chopolds's Avatar
Go to your autobody supply store and buy the assortment box. You will need at least 2 different sizes, maybe more. And it's cheaper than buying little packs of 3-6 nuts individually. I believe even Horrible Freight has them.
Old Apr 22, 2023 | 05:08 AM
Carsick's Avatar
[. I'll look eBay..thank you. The rear (By the windshield trim piece(es) had old adhesive. Should I dab some on the studs before I assemble? Do things rattle if not?
QUOTE=chopoldthankbyoilu
​​​​​​;1493508]Go to your autobody supply store and buy the assortment box. You will need at least 2 different sizes, maybe more. And it's cheaper than buying little packs of 3-6 nuts individually. I believe even Horrible Freight has them.[/QUOTE]
Old Apr 22, 2023 | 05:27 AM
Carsick's Avatar
Do these look good?
Old Apr 22, 2023 | 05:52 AM
chopolds's Avatar
Those will work, if the right size. The stuff on the nuts is not adhesive. more like a sealer, so water does not enter through the holes. I use "strip caulk", rolled into a donut shape, and put it both on the clip, and on the washer of the nut, to sandwich the hole with sealer. Here's the assortment:
Amazon.com: 60 Piece Emblem Script Name Plate Thread Cutting Nuts Compatible With GM 4 sizes 1/8" 5/32" 3/16" 1/4" : Everything Else Amazon.com: 60 Piece Emblem Script Name Plate Thread Cutting Nuts Compatible With GM 4 sizes 1/8" 5/32" 3/16" 1/4" : Everything Else
Old Apr 22, 2023 | 03:31 PM
therobski's Avatar
Carsick I wish you were close, ( Live in Dallas) have a bunch, all from previous "OLDS" builds you could have them...I bought them from Fastenal...
Old Apr 25, 2023 | 07:35 AM
Carsick's Avatar
That would be nice! I feel like I really over paid!
markxyzbc
Jun 6, 2021 06:03 PM
Chris6542
Apr 23, 2020 09:52 PM
cutlassefi
Jun 19, 2017 04:42 AM
442much
Mar 14, 2010 12:53 PM
beebee007
Aurora
Aug 17, 2006 06:45 PM
