specific replacement panels?
i was wondering if there is replacement panels i could buy instead of chopping or fabricating? i'll throw up some pics. the deck panel qeustion is just, is that the deck panel there i pointed out just checking on. that first is the trunk latch strip there where the seal goes and the next is the i guess the deck at the bottom of the front windsheild and then the 3rd is the water drain
Reproduction roof panels and windshield channel panels are available from the usual aftermarket sources (one advantage of being common with the Chevelle for these panels). The tail panel and trunk gutter is not reproduced so you'll need to find good used sheetmetal. Be aware that four doors, convertibles, and Supremes have different tail panels and trunklids and will not interchange.
