Sheet-metal below the rear window to trunk
Hi,
I'm new here and was wondering if anyone knows where I could find a sheet metal patch for my 1967 oldsmobile cutlass supreme. The patch I'm looking for is below the rear window to the trunk. My sheet metal is rusted out along the bottom of the rear window. Can anyone on here point me in the right direction.
Thanks Chad
Thanks Chad
I'm looking for the same piece but for a 442, I've seen aftermarket reproductions I believe are for the cutlass S models. Check out this link
http://www.thepartsplaceinc.com/ocat...ID=4&curpage=5
BP1269T (1966 - 1967 Cutlass/442) DECK LID FILLER PANEL REAR WINDOW TO TRUNK PANEL HT ONLY
Not sure if this elps but it may be worth checking out.
Hi,
Thanks Chad
Thanks Chad
if the channel is rusted on the filler panel more than likely you will be patching the under panel as well
some guys have said the OPG panel is the thickest replacement panel available
I did mine on my last car not to tough of a job
pics and write up are in my build thread
