Rust repair and paint 1971 cutlass
Old Oct 12, 2019 | 02:24 AM
rchavez03's Avatar
I have some rust on my trunk and hood that I'm trying to seal up before winter. Trying to tackle this myself, any tips, tricks or ideas would be greatly appreciated. Thanks in advance.
Old Oct 12, 2019 | 04:04 AM
scrappie's Avatar
Wow!
Is there any primer under that paint? Im no body expert but definitely looks like a step was skipped somewhere along the line or an inferior product was used? Raw metal exposed now and rusting so really only way is to sand, grind or blast rusted areas and apply a good primer preferably epoxy primer to seal and protect. It will obviously need to be painted. The rust will continue unless removed.
Old Oct 12, 2019 | 06:31 AM
Unfortunately, it looks like whoever painted that car previously did not prep the metal properly before painting it. You should strip it completely and remove all the rust before using a good quality 2K primer. If not, the remaining original paint under your new paint will continue to lift, taking the new paint with it.
Old Oct 12, 2019 | 09:53 AM
rchavez03's Avatar
Yeah, it looks like whoever painted it previously did a bad job. I appreciate the help, I guess I'll be doing a good amount of sanding this weekend. Thank you guys.
Old Oct 14, 2019 | 08:06 AM
akspeedy's Avatar
only way to deal with that is to start over!
j808702
Oct 11, 2017 04:23 PM
j808702
Oct 26, 2016 07:19 PM
Johnnie5
Sep 13, 2016 03:51 PM
blunce
Body work
19
Feb 16, 2013 08:16 PM
deweirdt
Jan 31, 2008 05:44 PM
