Replace or repair?
Old Aug 5, 2012 | 05:28 AM
smietana's Avatar
Replace or repair?
My driver has some rust, would it be better to replace it or repair?
Old Aug 5, 2012 | 05:52 AM
DarrylJ's Avatar
It don't look that bad, I would repair it unless you are looking for a concours restore. As long as the outside of the door looks good, nobody sees the inside.
Old Aug 5, 2012 | 06:34 AM
smietana's Avatar
Thanks, that is what I was thinking. This is going to be a nice driver only.
Old Aug 5, 2012 | 07:47 AM
Lady72nRob71's Avatar
No bad - I say try to repair it first. Once you grind out the rust, see what you have left. I am thinking you will have enough left to weld in some small hand-cut patch panels and make it look nice again. If you cannot weld them, try to find someone who can.
When done, clean the inside well and paint it all with POR15 to prevent future rusting.
Old Aug 5, 2012 | 04:21 PM
coppercutlass's Avatar
Chevy budget Olds powered
i had similar rust issues patch panles ad panel bond where my choice of weapons for the repair. i recreated the seam line where the door skin is folded over by running a really smooth bead of seam sealer they sell wide flat tips for the seam sealer bottles. posted pics so you could get some ideas I had to make patch panels on both sides outside and in foir this repair.
Old Aug 6, 2012 | 11:28 AM
smietana's Avatar
Thanks for the pics, helps out. Nice work.
Tom
fiebs442
Jan 11, 2015 07:05 PM
Mr Nick
Jan 12, 2014 04:05 PM
71supreme
Oct 24, 2010 09:10 PM
Steve Wike
Body work
Apr 23, 2010 05:53 AM
wjustinmartin
Feb 5, 2010 12:39 PM
