Question: Tire and fender clearance
Old Sep 23, 2020 | 07:17 AM
drkearnel's Avatar
Working on my 64' Cutlass / F-85 and I'm wondering if anyone has a "best route" to get rid of that huge bulge inside the rear fender. -pics attached of what I'm talking about.
If this was flat, or removed, the size tire that could for in the back could increase pretty significantly.
I'm sure some have done rid of this inner fender bump, just looking for what people have found to be the most successful and clean method.
Old Sep 23, 2020 | 08:16 AM
It might help to know what vehicle that is. I can't tell from the inside of the fender well.
Old Sep 23, 2020 | 09:09 AM
drkearnel's Avatar
Oops! Yes I meant to include that. It's added to the post, but it's a 1964 Cutlass
Old Sep 23, 2020 | 09:49 AM
Is that sheet metal or ???
Old Sep 27, 2020 | 06:28 AM
drkearnel's Avatar
Yessir OEM stamped steel
Old Oct 2, 2020 | 05:59 AM
drkearnel's Avatar
I could cut that "buldge" out very carefully with a wheel...bit then I'm concerned about keeping that sharp metal away from the tire!
Weld it to the fender after cutting? This wout likely mess up the paint on the other side, which while isn't perfect, I don't plan on painting any time soon.
Use panel bond material to hold it in place? Never used it so my personal confidence is not there for it to hold and look good.
Help
Old Oct 2, 2020 | 07:28 AM
Help
If you have the skills, cutting it out and welding it smooth is the way to go. I don't know about the panel bond.
Old Oct 2, 2020 | 12:50 PM
ROCKETMAN269V's Avatar
Here's a shot of the rear in my '65 Cutlass/442 clone, daily driver. It had a '70 8.5, type "O" rear end, which is an inch wider than the stock rear, with 275/60 15 BFG Drag Radials on it. At the track, I ran 28 x 9 slicks. Both sets of tires were on 15 x 7 SS III factory wheels. I had the body shop next door to me "massage" the inner wheel wells with large hammer and a little heat. The rear suspension was also modified to lift, rather than squat under acceleration. Edit: Just found a picture of a picture that I have in my office, of the car coming off of the line. Sorry for the quality. Quarters look factory from the outside.
Last edited by ROCKETMAN269V; Oct 6, 2020 at 11:12 AM. Reason: added additional image
Old Oct 6, 2020 | 11:13 AM
Additional image added.
MX442
Aug 26, 2012 06:45 PM
RAMBOW
May 2, 2012 07:02 PM
pick
Apr 11, 2012 07:11 PM
bonezarally
May 1, 2011 06:37 AM
nmtt92
Body work
Mar 23, 2009 05:00 PM
