Pleasee please help me.
Was adjusting the door... Had the striker loose and shut the door... Now i cant get the door to let go of the striker, its not locked. It feels like its just caught but the door WILLLL NOT OPEN FOR ANYTHING i even tried to just remove the whole door.. It wont let got
I had same issue in my 70. I went in with door panel off and jimmied around with a screw driver on the lock mechanism while a friend pulled in the door handle from outside with button depressed. Took a while but finally popped open.
The door never had problems b4 this. Today i did replace hinge pins and bushings so the door was off. But i dnt think i messed anything up..
Well after some in and out and a few beers i went back into the garage to take another look at that latch. I decided to just pop that plastic piece i talked about before out. Figured it couldnt hurt, it was already broken and couldnt get much worse. Popped that sucker out and walllah the latch works again. I think that plastic piece got smashed when i shut the door during adjustment causeing it to A. Break and B. block the latch from unlocking.
Dam thing had me going all dayy
Live and learn
Live and learn
