outer wheel house for 70 cutlass supreme
Old March 20th, 2017, 06:44 PM
1970greensupreme's Avatar
Am I correct in you need to use a convertible wheel house on a supreme? I've seen where it says some trimming may be needed but they don't offer convertible or supreme only parts.
1970greensupreme is offline
Old March 21st, 2017, 08:50 AM
TripDeuces's Avatar
I don't know the answer but I am wondering why the factory would use a convertible wheel housing just on Supremes? Is it because Holiday coupes didn't come as convertibles?
TripDeuces is offline
Old March 21st, 2017, 08:58 PM
Judging by the shape of the quarter, when you buy a replacement quarter or a repair panel convertible and Supreme use the same part. Inners are all the same from what I can look up at say Fusiks or other vendors. I don't even need the whole part, basically plan on using what I need near the wheel well and butt welding it in. The inners have a small area on both sides and they actually sell patch panels that should work out. BTW, I bought the same rotisserie as you did. Did you have to extend the arms to reach the body mounts in the front of the car like I had to?
Old March 21st, 2017, 11:08 PM
TripDeuces's Avatar
On my 66 the inner wheel wells are not the same. The convertible one is flat on the top so the top can sit down all the way. Maybe this is different on the 68 and up but I don't know that answer.
My front arms bolt right to the inner mounts under the cowl, no extensions.
Old March 22nd, 2017, 06:27 AM
oldspackrat's Avatar
On the '68-'72 A body convertibles the top of the rear wheel wells are flat also so the top lowers all the way. I have heard, but have no proof, that on the assembly line they used a large hammer to flatten the wheel wells on the assembly line. Might be an myth though...
oldspackrat is offline
The Bug Man
Body work
January 15th, 2013 06:58 PM
cut123
January 15th, 2013 12:40 PM
drshortt
June 4th, 2012 05:40 PM
tru-blue 442
November 16th, 2011 06:59 AM
mjm
June 14th, 2010 05:53 PM
Quick Reply: outer wheel house for 70 cutlass supreme
