Original or aftermarket?🤔
Old Feb 12, 2022 | 04:41 AM
72455's Avatar
1972 U code Supreme
I am going to be replacing the striker bolts and washers on my '72 Supreme, and while I like the idea of OEM, I ordered a set of these too.
What do you think?
Old Feb 12, 2022 | 07:08 AM
Schne442's Avatar
No it's not a parts car!!
The Parts Place has these
I installed a set and they look and function as original on my 72
1972 Oldsmobile Cutlass/442/F85 NEW DOOR LOCK STRIKER BOLT KIT WITH PLASTIC WASHERS (TORX HEAD - REPLACES GM # 20151275) Price: $25.00
Old Feb 12, 2022 | 07:10 AM
72455's Avatar
1972 U code Supreme
I have a set of OEM but I'm liking the black ones.
Old Feb 12, 2022 | 09:53 AM
Bfg's Avatar
Bfg
You answered your own question
Old Feb 12, 2022 | 09:54 AM
RetroRanger's Avatar
72 Olds CS
Ithink the black part thats painted will chip off!
Old Feb 12, 2022 | 10:13 AM
Without any question of doubt I would install the metal striker bushing. If you elect to install a black (or other color) bushing consider there are two types of manufacturing plastic/rubber pieces relative to their color: (1) The manufactured plastic/rubber piece is cast with the color pigments embedded into the plastic/rubber; or, (2) the plastic/rubber piece was painted after it was cast without color pigments which in this case the painted color is surely to chip and lose its painted surface.
Old Feb 12, 2022 | 05:36 PM
72455's Avatar
1972 U code Supreme
Well, I'm going with OEM...the black ones have no bushings and the washer has a loose fit compared to OEM...that as an easy decision.
Nov 18, 2021 11:41 AM
neutronbomb
Mar 22, 2017 09:46 PM
Sampson
Dec 28, 2014 07:41 AM
EightballZ
Mar 24, 2014 05:03 PM
oldzy
Brakes/Hydraulic Systems
Mar 31, 2011 08:17 PM
