olds in germany needs help with unnamed cover
Old Apr 13, 2013 | 10:42 AM
olds in germany's Avatar
Hello Forum, at first: sorry for my bad english!
I`m restoring a `71 Cutlass Supreme in North Germany. Next week he will get his paintjob. Now I have a problem: You can see the part at the pics. What kind of seal or cover must be placed on it. I think water will invade into body whithout any cover where the red line is on the pic. My hand is the window and the blue range is the original rubberseal.
At the most Cutlass Pics this part is painted, thats why I`m asking you: Should a part covered?
Old Apr 13, 2013 | 03:16 PM
2blu442's Avatar
OK, there is a rubber seal that goes into where your hand is. There should also be a stainless steel strip that attaches where the green line is. That has a wide rubber seal glued into it. I don't have a 70-72 supreme right now, but the Cutlass S of that vintage used a similar setup. If someone else doesn't come up with pictures first I'll snap some and post them for you.
John
Old Apr 13, 2013 | 04:16 PM
2blu442's Avatar
Here's the piece I think you are missing. The first few photos are of a 1969 with the piece installed. Then pictures of pieces I removed from a 1972 Cutlass S. Yours will be a different shape due to the back window, but I still think yours should have this stainless steel channel for the window seal to fit into. Let us know if this answers your questions or not. If your missing this channel I'd encourage you to post a parts wanted thread to see if someone here has extras they would sell. John
Here's a side view and the stainless trim you'd see once installed.
Here's the inside of the channel where the window seal fits in
Here's the top of the trim where it fits against the roof of the car. This fits against where your green line is drawn.
Old Apr 13, 2013 | 04:51 PM
1970cs's Avatar
Lansing built
Pics are from my 70 Supreme hardtop.
Pat
Old Apr 13, 2013 | 04:54 PM
2blu442's Avatar
Pat
Well, I could be wrong thinking they were the same as the Cutlass S for that vintage. Pat, does it look like there's just the rubber insert for the window channel?
John
Old Apr 14, 2013 | 06:26 PM
1970cs's Avatar
Lansing built
John
It appears that it is just a rubber chanel. I have never removed since both sides are in perfect shape for factory installed.
Pat
Old Apr 14, 2013 | 10:59 PM
Hey John and Pat,
thank you very, very much for your answers and pics.
@Pat: thats it! And if I cant find it, I will repro it simple.
I love the www and CO
Best regards Göran
Old Apr 15, 2013 | 08:21 AM
Seff's Avatar
The part of your car that you're pointing to is the rear edge of the rear window, yes? That part isn't covered by the parts 2blu442 posted pictures of - that part only fits up and forward in the door and window 'hole'.
There is a rubber weatherstrip (possibly with a steel core, I don't remember offhand) that fits in that particular place, i.e. the outside rear edge of the quarter window.
I'm in Southern Denmark and have the parts 2blu442 posted if you need those as well. I'm not sure I have the weatherstrip parts you asked for originally, and if I DO, I'm not sure they're worth putting back into your car.
billmerbach
May 16, 2014 11:39 AM
The_German
Oct 16, 2012 09:16 AM
sachseDD
Jun 15, 2012 06:58 AM
PushRod
Mar 29, 2010 04:09 PM
bebufire
Nov 24, 2009 06:16 AM
