Metal under dash/Cowl
Old Dec 10, 2018 | 11:50 AM
eJokl's Avatar
Question Metal under dash/Cowl
Hi, I'm restoring a '70 442 and I'm having a hard time finding a part that was rusted out. It's the metal at the base of the windshield but on the interior side. The cowl portion is fine but the piece that it's welded to is all rusted out. There was a crack in the windshield that might have let extra moisture in or something. Does anyone know the name of that part or where I can find a replacement? I just need the first 5" or so that I can wend in to replace the rusted part. It looks like its all one piece of the dash. The metal that makes up the dashboard interior. Any help would be appreciated. Thanks
Old Dec 10, 2018 | 12:54 PM
v8al's Avatar
Registered Olds Owner
Maybe your looking for something like this?
Auto Metal Direct Dash Top Repair Panels 465-3468
You can search for "Dash Top Repair Panels" but most are for early F-Body's. I don't believe anyone has reproduced this part for 70-2 Oldsmobile's yet.
Your best bet will probably be a used panel off a parts car. Check the classified section on this site.
Old Dec 10, 2018 | 01:09 PM
eJokl's Avatar
It's hard to tell if that part would work. Here's a picture of what I'm talking about. I'll try to get a not so close up photo tonight.
File Type: pdf
Old Dec 10, 2018 | 01:26 PM
scrappie's Avatar
Best to find a donor IMO. There might be something out there reproduced but Im not aware. Other GM cars of the era may interchange also?
Old Dec 10, 2018 | 03:28 PM
442crzy's Avatar
I have a complete dash clip from a donor car rust free, PM sent.
Old Dec 11, 2018 | 04:44 AM
Eddie Hansen's Avatar
are you talking above the channel? Or under it? I replaced my front channel with a Chevelle piece there is enough excess metal to fiddle with ( straitened hammered and dolly ) to fix a portion of the dash look toward the end of my build thread to see what I mean
Old Dec 11, 2018 | 06:39 AM
This is what I did
If you can get original metal it is the way to go, however, you will still need the windshield channel? how will will you weld inner and outer? I repaired my inner first, doesn't have to be perfect, I used sheet metal and a pair of dividers to get the curve, then welded it in. then cleaned it up. for the dash there may be enough metal to repair the dash, if not you will need the whole dash depending on your skills, its possible to fabricate anyway looking at yours and what I had looked similar. pictures kid of tell the story...
Old Dec 11, 2018 | 06:50 AM
The repro parts available are for Chevelles. There are some differences on the Cutlass. The Chevelle parts require some work to be used.
Old Dec 11, 2018 | 07:16 AM
Joe , yes mine is from a Chevelle, even though I bought it from Fusick, wasn't terrible to use though, but did need work (tweaking) as you stated
Old Dec 11, 2018 | 07:20 AM
hmmmmmm
How to replace both parts at the same time? am I missing something? if you get from a donor the inner and outer are welded together, so you will need to grind off either the inner and outer? This was my first channel repair and I am no expert either lol
Old Dec 11, 2018 | 08:07 AM
scrappie's Avatar
Looks good Eddie, nice work
Old Dec 11, 2018 | 11:00 AM
eJokl's Avatar
Yea that looks great man. The outer portion of mine including that plenum space is in pretty good shape. Mine pretty much exclusively rusted inside the windshield. I'd probably just grind off the inner portion and replace it with a patch. I just found this. Not sure if it's the same but looks similar.
Old Dec 11, 2018 | 11:18 AM
v8al's Avatar
Here are the AMD panels that are available. You may be able to get the metal you need off one of these panels.
AMD Dash panel
Old Dec 11, 2018 | 12:42 PM
You might want to click on the APPLICATIONS tab for that part. It's for a first gen Camaro/Firebird. Different width and shape than an A-body.
Old Dec 11, 2018 | 01:10 PM
eJokl's Avatar
Good catch. I think this might be my best bet. It doesn't look right to me but maybe it's just the perspective of the picture or something.
https://www.summitracing.com/parts/amd-465-3468
Old Dec 11, 2018 | 01:19 PM
That is your only bet. There are no other options.
Old Dec 11, 2018 | 01:20 PM
That is the part I bought, parts place, fusicks etc have them as well. amd only makes the more complete top part for a 1967 chevelle, :-(
Old Dec 11, 2018 | 01:26 PM
hmmm
http://www.fusickautomotiveproducts....?number=FCA702
Old Dec 11, 2018 | 01:46 PM
eJokl's Avatar
https://www.getallparts.com/Aftermarket-/p/GMK403252168
found one for $50. Pretty good. I'll have to do an update once I get it in.
Thanks for your help everyone
Old Dec 12, 2018 | 05:18 AM
lemoldsnut's Avatar
make sure you test fit a windshield as you progress in the repair. Just a reminder.
Old Feb 26, 2019 | 05:13 AM
Billyaxe's Avatar
Installing this on my 68 442?right now.
Ultra Tweaker
Body work
Jan 2, 2019 07:00 PM
yamahondarider
Body work
Apr 25, 2014 10:37 AM
Johnd
Body work
Jan 27, 2012 09:30 AM
alek72us
Body work
29
Jan 24, 2011 04:41 AM
