'68 442 windshield cowl/dash rust. Looking for solid donor.. Which years/makes?
Old August 3rd, 2013, 09:48 PM
oldsmosteel's Avatar
Hi all my 68 442 will be needing some dash/cowl rust repair right below the windshield. I can see that the metal has bubbled up all the way across the bottom of the windshield. I know more than likely a large section of metal will need to be cut out & replaced. Questions are... What is the quality of the new aftermarket pieces? Who makes good ones? I've read that some of the new aftermarket cowl replacements don't usually cover most of the dash.. Is this true? If I am better off finding a solid donor which years & makes would be a perfect fit? sorry to upset the olds purists but living in SoCal I run across a quite few 68-72 A-body part outs from time to time.
Thanx in advance
Marty
oldsmosteel is offline
Old August 4th, 2013, 03:06 AM
allyolds68's Avatar
You should post a picture. Bubbling can be fixed but you're correct, it usually ends up being a long hole once you pull the windshield. The dash is specific to 68-69 olds. Chevelle, GTO, or GS aren't the same. There's isn't a patch panel available for the Olds.
allyolds68 is offline
Old August 4th, 2013, 11:05 AM
NOVICE car nut
oldsguybry's Avatar
You will need a donor car to fix , or you can fab a piece of metal in there
oldsguybry is offline
Old August 4th, 2013, 10:46 PM
thanks guys. i'll post a pic of the dash & post pics of my progress... got a lot of rust repairs... so there will be a lot of progress to be had.
Old August 5th, 2013, 10:13 AM
NOVICE car nut
oldsguybry's Avatar
I'm in the same boat with the dash . My rust goes all the way across the dash , and the rear window along with the roof .
Johnd
Body work
March 26th, 2014 04:46 PM
rcktdoc
January 6th, 2014 08:46 AM
tailfins
September 18th, 2013 12:34 PM
rket56
October 15th, 2012 05:22 AM
Johnd
Body work
January 27th, 2012 09:30 AM
Quick Reply: '68 442 windshield cowl/dash rust. Looking for solid donor.. Which years/makes?
