Losing wood...
Old Nov 18, 2010 | 06:26 AM
auto_editor's Avatar
Got wood? I do! (an '89)
Losing wood...
If anyone knows how to stop the loss of "wood" trim I'd sure like to know about it. I have some rust-related loss I'll address in another question, but what can I use to stop the "sticker" from un-sticking? It's only happening near the lower chrome belt line just behind the front wheel openings.
Drew
Old Nov 18, 2010 | 07:25 AM
Lady72nRob71's Avatar
Smear a little clear drying epoxy around the edges of the flaking stuff?
That would hold it in place so the wind will not keep lifting it away...
Old Nov 18, 2010 | 08:59 AM
Bluevista's Avatar
Registered
The vinyl shrunk and pulled away from that lower area and spanned instead of followed the contour just below the body line The surface wasn't prepped right, vinyl wasn't applied correctly, applied at the wrong temperature, encounter with edge of chain link fence.
If it's applied right it sticks forever and will take the paint off with it when you try to get it off.
You aren't going to do much other than seal it up with something like Rob said to keep it from getting worse. Probably a bubble under that line all the way around the car. You may be able to take a hair dryer and soften it up if it isn't too brittle and push it down but it would probably pop right back soon as it cools unless the adhesive is still tacky.
Old Nov 18, 2010 | 10:33 AM
Nilsson's Avatar
Isn't that what Viagra is for?
Old Nov 18, 2010 | 10:54 AM
Shoot! You beat me to it.
Old Nov 18, 2010 | 10:56 AM
Contact paper for shelving comes in woodgrain - might make a good temporary patch for the big holes...
Or get a lot and redo the car!
Old Nov 18, 2010 | 10:57 AM
Rickman48's Avatar
Me three - - -
Old Nov 19, 2010 | 04:47 AM
Willidog's Avatar
Official Tire Kicker
I was thinking along the same lines when I read "losing wood."
Old Nov 19, 2010 | 07:01 AM
We journalists are known for our entendres...
Old Nov 20, 2010 | 07:37 AM
Getting back on topic, shelf paper is NOT UV-stable and will not last very long on the sides of the car. Note that the factory woodgrain vinyl is much thicker and has a clear layer over the woodgrain.
fmay50
Dec 17, 2009 10:45 PM
Sam Barrett
Nov 4, 2009 06:46 AM
DAN76
Aug 8, 2009 07:13 AM
MN71W30
Feb 22, 2009 11:09 AM
jaco
Jan 20, 2007 06:42 AM
