Interior hood work on 64 88
I purchased the pad at USA Auto Parts$32.55 delivered. A bit thinner then original but does the trick. Caution it can tear easily!! The fasteners are floor drain covers I purchased at home depot and I bought stainless bolts. I think the fasteners give it a better look then the small original ones, and given the fact I did not glue it to the hood it seemed prudent to attach the pad with larger fasteners. Thanks
http://www.rubbertherightway.com/#lo...er_id_61=61|63
I purchased hood insulation for my '67 Delta from this site, and it is just fine in shape, thickness, and appearance. It's U.S.-made. It's $24.50, but I don't know if that includes shipping.
My pad came with 5 fasteners at no extra charge. I don't see fasteners included for the piece for your '63, but those fasteners are only 75 cents each at Fusick. The only problem is their $25 minimum purchase. But fasteners can likely be gotten from other sources, if not from Rubber the Right Way itself.
leroycjr...I gave it a good sanding and then applied a rust inhibitor purchased from a national brand parts store. ( small bottle @ $6.00) I applied two coats of primer and then two coats of high gloss auto paint...NOTHING FANCY. And as I wrote before I used floor drain covers purchased at Home Depot and stainless bolts. I did not use any glue on the hood.
I have a question about this.
What is the purpose of the hood pad? As I understand it, it is to both act as a sound deadener and to protect the hood/paint from the heat of the engine.
By using metal fasteners, you have partly defeated the second purpose by providing a direct, metallic pathway between the engine side of the pad and the hood side, and as we all know, metals are about as good at conducting heat as they are at conducting electricity. So at least in the five spots where you have those stainless steel bolts, you have potential hot spots on your hood, including one right in the middle.
What's worse, those five large, round metal covers add to the problem by significantly increasing the heat transfer area. If it was just the heads of the bolts sticking through, it would be one thing, but the surface area for heat transfer has been increased significantly by the use of those round covers.
Does this all matter that much in the end? Probably not. But the reason that factory hood pad fasteners are made of plastic is probably not just because plastic is cheap. For one thing, it's also a poor heat conductor.
I just did a little bit of math here. I'm guessing those round metal covers are, what, 4 inches in diameter? Together they have a surface are of about 63 square inches (5 x pi x 2^2). If you had used, say, round plastic of the same diameter but kept the stainless steel bolts, and assuming the bolt ends are, what, 1/2" in diameter, the total area of the five bolts by themselves is barely 1 square inch (5 x pi x (1/2)^2).
So you have increased the heat transfer surface area by a factor of 63.
Jaunty the original clips I rec'd were metal.. I take it you have never used your imagination on anything on your car, never changed a thing...you have way too much time on your hands to figure those numbers. How about this: Man sits at home multiply by boredom divide by who gives a @#$% = an opinion not required
But there are also times when no imagination was needed as a simple solution was available and straightforward.
No offense was intended. I stated what I thought was a very reasonable objection to what you did when factory-correct fasteners are available and dirt cheap.
If you want to run off and have a temper tantrum about it, that's fine, but childishness on this site is something we don't need.
haha navvet looks good nice job and i appreciate the ingenuity
jaunty its also nice to see the indepth analysis of the heat transfer which as you noted probably doesnt matter much at all
all in all it makes for a good read
smkn600ctd
December 29th, 2014 05:38 PM
