installing cruise control on 70 cutlass
Old Jan 4, 2024 | 02:58 PM
joeyg's Avatar
Looking to see if anyone has a picture of the speedometer cable passing through the firewall. The instructions say drill hole at dimple next to the accessory grommet, cant locate the dimple.
Any pictures please?
Old Jan 4, 2024 | 03:36 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I would think the cable from the cruise control would go through the firewall where the current speedo cable goes. I am going to put cruise in my 75 Hurst Olds this winter. I got most of the under hood stuff when I bought the car. I have recently purchased the turn signal switch and the off/on switch and bezel that goes on the dash. I have the shop manual but no instructions for installing the cruise control. I don't think it is going to be a problem though.
Old Jan 4, 2024 | 04:06 PM
joeyg's Avatar
No the cables are different lengths, the instructions are clear a hole must be drilled into the firewall. The original cable enters from the bottom of the firewall the replacement cruise cable enters next to the accessory grommet.
Old Jan 4, 2024 | 04:15 PM
redoldsman's Avatar
Got you. I imagine my 75 may be the same.
Old Jan 4, 2024 | 04:27 PM
rcorrigan5's Avatar
Randy C.
My '69 4-4-2 has factory cruise control. Here is a pic of where the cable from the speedometer to the transducer passes through the firewall. It is just to the driver side and low to the brake booster. I don't know if it's the same for '70.
Randy C,
Old Jan 4, 2024 | 09:14 PM
redoldsman's Avatar
Thanks. That is probably the same or similar on the later models. The real PIA is going to be getting to the back side of the speedometer. At 77 and several extra pounds, it is going to be a lot harder to get up under the dash.
Old Jan 4, 2024 | 09:16 PM
Glenn, you may just want to yank the dash and LED the cluster while you are at it for getting access.
Old Jan 5, 2024 | 07:49 AM
redoldsman's Avatar
Thanks John. It is going to be a winter project. Of course winter projects in Texas are a little different since we tend to drive our cars year round. I have to go to the warehouse and get the box with all the other parts in it now that I have the switches. I have the LED lights for the cluster which it needs.
Old Jan 5, 2024 | 10:21 AM
joeyg's Avatar
Thanks for the picture.. looks like your cable is passing through the accessory grommet. My grommet is full because I have a convertible...
Old Jan 5, 2024 | 01:08 PM
rcorrigan5's Avatar
Randy C.
I didn't mention in the picture I provided that my '69 is a 4-4-2 convertible. It's heavily optioned, including A/C, pwr windows, auto trans on the console, pwr disc brakes, pwr steering, AM/FM stereo, SSI wheels, rally pack and even front seat shoulder belts.
Randy C.
Old Jan 5, 2024 | 01:39 PM
joeyg's Avatar
Kool very nice, but I have a hood lock release, so the accessory grommet has the cruise vacuum hose, the electrical cable for the top and the hood lock release so it's full, so I need to drill another hole but cant located the dimple as per the instructions!!!
Old Jan 5, 2024 | 03:40 PM
tnswt's Avatar
'70 4-Speed W Machine
I have both an electronic and hard copy of the PIM, but too lazy to get up and put my hands on the hardcopy. Hope this picture from my electronic copy helps.
Old Jan 5, 2024 | 03:48 PM
joeyg's Avatar
Thank you I have the same page but no dimensions for the hole just says dimple which I cant find. That's why I was hoping for a picture of the firewall.
Sep 21, 2020 05:30 PM
70-455
Aug 27, 2020 01:56 PM
70-455
May 17, 2020 05:26 PM
Greg Rogers
Aug 14, 2017 03:47 PM
98 man
Ninety-Eight
Jul 31, 2014 07:50 PM
