Inside fender supports
Old Feb 25, 2011 | 06:19 AM
oldsguybry's Avatar
NOVICE car nut
Hey , I thought I would ask the experts on this matter....I once again need to take fenders off and deal with a little rust behind the brace spot welded to the inside of the fender... my ideas now are to remove brace from fender , so i can get to all the rust spots that i cant normally get to. I dont weld so someone would have to spot weld this piece back on. question 1 , whats a good drill bit / technique for this job , and why did GM leave big holes where fender bolts up near the windshield , so all the leaves could blow down into fender ? I use an air compressor every year to get any leaves and helicopters that do get down there , a more permanent solution is to put a plastic or metal screen so nothing can fall inside fender anymore.... thanks in advance
Old Feb 25, 2011 | 10:37 AM
oldsguybry's Avatar
NOVICE car nut
also , I can get those special drill bits from hardware store to drill out spot welds ....right ?
Old Feb 25, 2011 | 11:57 AM
69442C's Avatar
Doubtful that your local hardware store will sell the spot weld cutting drill bit. That's likely a specialty item from someone like Eastwood Company or similar. It can't hurt to check with your local stores as some independents may carry it but I'd be surprised.
As for removing the brace, the first thing I would do is to drill a couple of 1/8" holes that go through the fender flange and the brace and do this where there are not any spot welds. Put a coupld of wheel opening molding screws or similar through these holes as this will give you a perfect reference to put the brace back exactly where it was originally by using these srews to align everything during re-assembly. Depending on the spot weld cutter you buy, you may have to drill a small hole through the center of the spot weld to guide the bit so it doesn't walk all over the place. That little hole in the brace should be welded closed before the brace goes back on but be sure you don't weld the alignment screw holes closed. Whoever does your welding will need to use a mig and not a spot welder as the cutting bit you use to remove the spot weld will leave a hole the size of the bit in the fender flange. That's OK as it makes for a nice plug weld because when the the hole is welded shut it's also welded to the fender brace to secure everything back together. Put a good epoxy primer on the back of the brace and fender to seal that metal before you re-attach the brace.
Old Feb 25, 2011 | 12:52 PM
oldsguybry's Avatar
NOVICE car nut
Thanks for the input , learned something new already , I was wondering about one other thing.....I only put one coat of POR 15 on inside trunk pockets and along wheel well lips....I should of read instructions better i guess , cause it says to put multiple coats on ...so can i re-coat over that after a year went by ? couldnt find a definate answer on that one , so any input on this would be appreciated.
Old Feb 25, 2011 | 01:22 PM
69442C's Avatar
Sorry, I've never used the POR products so I am not familiar with their application. BTW, should have mentioned earlier after the brace is welded in place, remove the screws and weld those small holes closed. Good luck.
Old Feb 25, 2011 | 02:35 PM
gearheads78's Avatar
car guy
Post picures of the rust. I spot weld cutter is usually not the best way to go in this case. grind the outside metal away at the spot welds is much quicker.
Here is a fender repair I documented recently. Go down to the bottom of the page.
https://classicoldsmobile.com/forums...1-10-a-10.html
Old Feb 25, 2011 | 04:21 PM
oldsguybry's Avatar
NOVICE car nut
cool thanks guys....
Old Feb 25, 2011 | 04:52 PM
69442C's Avatar
Gearheads, he is removing the complete rear brace on the fender, top to bottom, so he can access the area covered by the brace. Once he cleans and protects that normally hidden area, the brace will go back on. Grinding away the metal is not the way to do this since no pieces are being sacrificed. A spot weld cutting tool is the way to go.
Old Feb 25, 2011 | 06:57 PM
car guy
I know thats what he said he wants to do but taking the whole brace out is much easier said than done. Thats why I wanted to see picures of where the rust is and what he is really trying to do. If there is rust in the brace then there has to be rust in the much thinner skin.
Old Feb 25, 2011 | 08:33 PM
oldsguybry's Avatar
NOVICE car nut
once I get fender off , I will post pics of rust....this may be awhile though , was planning to do this when weather gets nice. also , there is a decent size hole there that i filled with bondo like 6yrs ago ....so the rust is mainly on the inner part of the brace now and of course the edges where the bondo started to seperate.....this is the reason i think the brace may have to come off , or at least part of it , in order to get to the affected area....not much room between brace and fender to get at rust
Old Feb 26, 2011 | 06:25 AM
69442C's Avatar
My advice comes from experience as I have done exactly as he is describing. I had a 69 442 fender that had rot in the bottom that weakened the lower section of the brace. In evaluating the repair on the brace, I also noted there was other surface rust on the back side of the fender skin trapped between the brace and fender. So I removed the brace, rebuilt the lower section of the brace and fender, cleaned up the inside of the fender, epoxy primed everything and welded it back together. While grinding metal away at the lower area to eliminate the welds if rust is there is fine, it is not the way to deal with the spot welds on the solid peices of metal and where the majority of those welds will be. I'm just trying to point out how this should be done as the suggestion of grinding away the spot welds implied to do it for all of the spot welds.
The bottom line was I felt this was a much better repair and would last much longer than leaving everything together to weld in patches. It's more work but worth it in the end. Also, all metal work is covered with a skim coat of fiberglass filler first as it is waterproof. Bondo is not. Sand the FG filler and then use Bondo to do the final repair. In the end, you shouldn't need to repair that area again.
Old Feb 26, 2011 | 07:39 AM
oldsguybry's Avatar
NOVICE car nut
yea , i realize how much fun it will be getting all the spot welds removed , im glad i only have to do this with the fender , and not the rear quarters or something. You guys are a huge help already , and i appreciate it.....will post some pics on this matter , and I also plan on doing frame off resto as soon as i have a decent place to do it....I will have lots more questions.
442mark
Aug 30, 2013 04:06 PM
mhartley
Jan 24, 2011 11:39 AM
6inarow
Dec 8, 2010 06:59 AM
moezart
Sep 23, 2010 04:29 AM
muddy
Jun 10, 2006 04:24 AM
