Inner fender removal
Old Mar 21, 2009 | 12:27 PM
nmtt92's Avatar
Does anyone know if it is possible to remove the left side inner fender without removing the fender? Car is a 66 Cutlass.
Old Mar 21, 2009 | 01:45 PM
2blu442's Avatar
I believe so. I recently removed the passenger side from a 1967. I put it on jack stand, removed the tire, removed all the bolts from the inner fenderwell and then rotated the top inward toward the engine. That got the wheelwell free from the fenderwell lip. Then I jiggled it around until I was able to work the rear downward and pull the front away from the core support. I rolled it out over the brake drum. The greatest challange was getting it off the fenderwell lip, but it was still much less time consuming than removing the fender from the car. John
Old Mar 22, 2009 | 10:22 AM
Run to Rund's Avatar
2blu remembers correctly. Removing the outer fender would be a huge pita. Just remember the pesky bolt at the bottom rear in addition to those around the fender lip, two inside at the top, and four across the front. Often the front ones are rusted badly on the side with the battery. Not only do you need rust penetrant, the heads are often corroded smaller so you should try smaller 6 point sockets if needed. Stock was 1/2" and 12 mm may fit.
Old Mar 23, 2009 | 05:00 PM
nmtt92's Avatar
Thanks -- got it done today. Was able to mostly remove the inner fender. Got it far enough so I could get my hand behind the fender to re-attach the fender trim piece.
Thanks for the info.
-- Jeff
kansjfr
Nov 6, 2014 06:50 AM
dsolomon
Apr 10, 2012 05:36 AM
rkk69olds
Jun 7, 2011 02:59 AM
davebw31
Mar 25, 2011 06:55 AM
lil_no
Feb 11, 2008 12:41 PM
