How to remove trim from 66 cutlass convertible
Old Mar 7, 2017 | 06:45 PM
joes66olds's Avatar
I'm wanting to take all the trim off my 66 cutlass convertible to start doing body work. How do I get the trim at the bottom of the back window off,I don't want to mess it up,removing it so I need some info in it.thanks
Old Mar 8, 2017 | 04:26 AM
35tac's Avatar
Joe, I believe you are describing the pinch weld molding which surrounds the convertible top above the trunk. Fischer Body manual helps some but not much since the manual is a guide to professional body technicians. You can see some information by searching You Tube under "convertible pinch weld molding" Need a special tool to remove the molding off the clips. Original Parts Group sells repo moldings and clips which might give you an idea about what you are up against. I haven't done it either but a convertible top installer might help you out. Mine is loose to move back and forth and I need to fix it but car is not out of storage. Hope this helps a little.
Wayne
Old Mar 8, 2017 | 07:40 AM
lemoldsnut's Avatar
There is two styles of this pinch weld molding. If you have reveal moldings. It has a screw at the leading edge by the quarter window that is hidden by the front of the quarter reveal molding. If you do not have the reveal moldings the front edge is different. Do you have reveal moldings at the top of the door and quarter by the windows?
The picture of my car in the avatar of this site shows no reveal moldings. I can provide another with the reveal moldings if you need to show you the difference.
Larry
Old Mar 8, 2017 | 07:45 AM
lemoldsnut's Avatar
The picture of my car here where it is drying from just being washed shows no reveal moldings (top of the quarter by the window and top of the door shell by the window) the other picture it has them. They come off different so that is why i am asking.
Old Mar 8, 2017 | 08:33 AM
35tac's Avatar
This what my pinch weld moulding looks like. It is sliding back and forth easily so I assume the screw is not there or loose. I believe Joe's 66 has the same moulding based on the picture he has in his bio. Neither I nor he know how to remove the moulding.
Wayne
Old Mar 8, 2017 | 09:02 AM
lemoldsnut's Avatar
Ok so no reveal molding. So this is very easy. put the top down and pull it off. Yup that easy. Pull from the side at the forward point by the quarter window and it will pull off slowly. The clips pinch the pinch weld and wedge in the molding. when you do not have reveal moldings there is no screw
Old Mar 8, 2017 | 03:39 PM
35tac's Avatar
So why is the moulding sliding back and forward on my 66.
Wayne
rr1964purple
Jul 9, 2016 05:23 PM
Carsick
Sep 28, 2015 05:39 PM
HitTheHole
Jun 30, 2014 03:12 PM
KRICHEN922
Jul 1, 2010 09:17 AM
Autobahnzerreisser
Body work
25
Jan 13, 2010 07:03 AM
