How is the rear quarter attached to the wheelwell?
Old Dec 28, 2017 | 01:30 PM
lshlsh2's Avatar
71 cutlass convertible
71 cutlass convertible. On my patch panel I am wondering how the wheelwell is attached to the quarter panel. Spot welds or some kind of glue? If glue will heat weaken it so I can get them apart. Thanks
Old Dec 28, 2017 | 01:35 PM
2blu442's Avatar
Back in the day they were spot welded. But there has been some discussion about new technology of glue that people are using. I don't remember who's thread, but if you do a search you might find it. John
Old Dec 28, 2017 | 01:59 PM
lshlsh2's Avatar
This would be from the factory.
Old Dec 28, 2017 | 02:40 PM
m371961's Avatar
In 71 all metal was joined by welding. Using adhesives came much later.
Old Dec 28, 2017 | 02:54 PM
cherokeepeople's Avatar
welded.go buy a snap-on ga219b i believe is the part number.these will cut just to the outside of the spot welds.then grind down whats left
Old Dec 28, 2017 | 03:06 PM
lshlsh2's Avatar
Thank you
Old Dec 28, 2017 | 07:08 PM
coppercutlass's Avatar
Chevy budget Olds powered
You can also just use a cut off wheel to grind the welds down and then chisel the old panel off once the top panel and weld have been weakened.
70-442-W30
Mar 5, 2016 01:10 PM
Qwik71442
Jan 26, 2016 11:13 AM
olddaz
Jan 11, 2011 11:09 AM
agtw31
Jun 3, 2010 03:16 AM
