hood hinge
Old Jun 4, 2014 | 12:34 PM
Double D Farms's Avatar
hood hinge
The driver's side hood hinge on our '69 Cutlass wants to fold down before the pass side. It was like this before we took everything apart to paint it. We put new springs on the hood when we put it back on but that didn't make a difference. The driver's side fender & front of the hood showed some damage from a minor wreck years ago when we stripped them. While the hinges were off I layed them side by side & couldn't see any damage. Do you think the hinge could be tweaked, or is something else going on? None of the usual suppliers have a new hinge in stock, they're all on back order.
Old Jun 4, 2014 | 04:15 PM
jag1886's Avatar
Hate to ask a dumb question, did you soak them in penetrating oil, mine did that and also wouldn't close down flush with the fenders and lubing them made them work like new.
Old Jun 4, 2014 | 04:24 PM
X2 on some lubrication.
Old Jun 4, 2014 | 07:56 PM
Didn't do that, but I did work a bunch of lithium grease down into all of the pivot points. Do you guys think the grease is too thick? If so I'll try oil.
Old Jun 5, 2014 | 01:28 AM
nsnarsk65cutlass's Avatar
The pivot point rivets wear out and that happens oil helps,but doesn't take away the wear.
Old Jun 5, 2014 | 07:58 AM
ROCKET VAPOR's Avatar
Lance
Willie can restore your original hinges to like new condition.
http://www.hoodhingerepair.com/
Old Jun 14, 2014 | 06:32 PM
Fixed
Got a used hinge from oldspackrat. Worked like a charm. Hood doesn't dip down at the cowl now. We got everything as lined up as it's going to be. Thanks Scott!
Old Jun 15, 2014 | 07:41 PM
oldspackrat's Avatar
Glad to hear it worked out for you. Thanks for your business!
RetroRanger
Nov 11, 2024 09:45 AM
sx455raidercelticfan
Jul 11, 2010 08:36 PM
sebastien
Body work
May 17, 2010 01:51 PM
mont1le
Feb 8, 2010 01:41 PM
Nilsson
Aug 21, 2009 03:32 PM
