Fyi: Cracks in OAI hood metal under frame
Old Aug 27, 2025 | 09:33 AM
soundhd's Avatar
Thought I would pass this on to all of you who own a 70-72 Cutlass with the W-25 OAI Hood option. Have noticed small cracks in the metal sub frame side rails on mine. Going to have a shop weld them up... Have included photos. Suggest you all take a serious look at yours....
left side
left side
left side
left side
left side
left side
right side
right side
right side
right side
right side
right side
Old Aug 27, 2025 | 10:27 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
OAI spec hood springs?
Hinges well oiled?
Be nice if the welder could fit backer plates in the affected areas, plug-weld those in then stitch the crack closed with a fine TIG...grind/paint/gone.
Definitely search for a seasoned body guy to do this.
Old Aug 27, 2025 | 12:42 PM
soundhd's Avatar
Had the car for 25 years…assume correct springs (guess will look into that)…lubed with Deep Creap….
Old Aug 27, 2025 | 03:24 PM
OLDSter Ralph's Avatar
Hinges well oiled?
I would add one thing. Drill a small hole at the end of each crack in the sheet metal to terminate the crack. Dremel and small diameter carbide would work. .
Old Aug 27, 2025 | 06:04 PM
Funkwagon455's Avatar
55 years…. Nothing lasts anymore!😂. This is normal maintenance for these hoods. Some have faired better than others, (or worse!) Proper lubrication is the key to preventing the problem. Repair, ensure proper operation, lubricate and go on down the road.
Old Aug 27, 2025 | 07:03 PM
It's a fatigue crack. Those notches are part of the controlled front end collision design to minimize the risk of decapitation in an head-on. Unfortunately these cars were barely designed to last ten years. Half a century is well beyond anything intended. Stuff happens.
VI Cutty
Body work
May 18, 2025 08:27 AM
prlynch01
May 5, 2022 10:05 AM
fasteddy
Feb 26, 2019 06:09 AM
teamwieland
Oct 15, 2018 07:23 PM
BSiegPaint
Mar 6, 2018 05:09 AM
