floor pans
Old Sep 13, 2010 | 02:23 PM
73 d88's Avatar
floor pans
ok heres my problem.i have a 73 delta 88 royale.no body parts available exept used.so i have to replace floor pans.so what gauge steel should i use .and what do i use to coat it and ready it for carpet.
Old Sep 13, 2010 | 04:39 PM
ent72olds's Avatar
Registered Luser
Used IS your best bet!
Used pan sections from out west would be the way to go! Carefully remove old, and install new...much quicker and cleaner looking! Or check with John(2blu442) and see if he has one of those cars laying around!
Old Sep 21, 2010 | 04:52 PM
gbodyfan's Avatar
I would suggest 18 ga. if you are just gonna patch it in plain steel.
Old Sep 22, 2010 | 06:31 AM
73 d88's Avatar
thanks cuz i dont think im gonna find pans.has anyone taken pans off of somthing else and put them in.i was thinkin it would look better than just flat steel.any suggestions is great.and also i have a 93 taurus can i use the skin on my older car or do i need to go get like a hood off an older car for that.
Old Sep 22, 2010 | 07:23 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I'd just use the taurus floor.
Ribs are stamped into the GM floors to maintain rigidity, because they wanted to save a few bucks and find out a good way to stick us with thin gauge crap steel.
In my opinion, there is nothing good to be said about originality on many GM parts. the floors being one of them.
If you want to run a flat patch, go with thicker gauge so it doesn't pop and flex on you.
Or just use the taurus floor and beat the ridges flat around the weld edges.
jon1957
Body work
16
Nov 2, 2018 09:10 PM
pinky
Paint
Mar 16, 2009 07:03 PM
jasonjtrahan
Sep 18, 2007 09:54 PM
19594mydad
Jul 8, 2007 07:42 PM
bmwashington
Apr 25, 2007 10:21 AM
