Filler suggestions
Old Jul 7, 2017 | 02:46 PM
67Rocket's Avatar
Filler suggestions
What brand of filler do you guys suggest for minor door dings and hail dents? Thanks
Old Jul 7, 2017 | 03:17 PM
coppercutlass's Avatar
Chevy budget Olds powered
For minor fill evercoat metal glaze is great. If not the rage gold is good.
Old Jul 7, 2017 | 03:29 PM
X2 on the Evercoat, just watch the shrinkage after it dries. You may need to give it 2 coats and resand.
Old Jul 9, 2017 | 03:10 AM
tommieb's Avatar
Yes to the above. In my sho been using the Evercoat Rage ultra sands great but look close may have micro in holes so finish with Evercoat metal glaze
Old Jul 10, 2017 | 03:33 AM
chopolds's Avatar
I do some pretty nice custom work, and paint and I've never been too fussy about what type of filler I use. As long as the work under it is good (solid welds, dents worked out to less than 1/4") any quality filler will work. Stay away from real cheap stuff. I like lightweight filler, as it's easier to sand. I even use my autobody supply's store brand.
Once you get down to the filler work being almost perfect, THEN you can do any final fixing with Evercoat Glaze, or Icing. It's meant for less than 1/16", so only pinholes, minor scratches, or low spots.
CLcutlass
Paint
28
Feb 6, 2020 05:57 PM
67Rocket
Body work
Mar 23, 2016 04:22 PM
dvdmizer
Oct 12, 2006 12:35 PM
emarkay
Aug 9, 2004 08:12 AM
