Exterior floor pans. At a cross roads
My 67 442 was painted in 99 and buffed our well enough not to justify painting it. I am taking the body off the frame though to paint the chassis and re-Bush everything. I had to have a poor (riveted in) drivers pan welded in so I do have some exposed bare metal to take care of. This car will be a nice driver.
I’m at a crossroads to either re undercoat it all including that pan repair or just that area and was thinking of power washing the bottom and was wondering if you can paint the dirty brown all factory undercoat. I’ll have this super clean chassis and really don’t want to see that dirty old floor pan.
Any suggestions or pics you have?
I'm confused. You're going through all the trouble to blow the car apart and pull it off the frame any your question is about how to cover what you've described as a less-than-properly-done floor pan patch? Once you have to cut holes in the floor to access the body mount cage nuts that break loose and spin, you'll hopefully realize that you need to do a proper floor pan repair.
Perhaps I wasn’t clear enough. I bought the car last July. And one point a new floor pan was riveted in. I had the rivets and silicon removed and the pan was reused and butt welded in. There was so much overlap in the rivet job we were able to reuse the pan. The car was bought in and always in dry Eastern Oregon. I am extremely confident there won’t be any issues on body to frame fasteners.
I hope I don’t have to cut holes in any pans.
I can think of two reasons why you don't want to do this. First, all you can access is the head of the bolt. The cage nut with the threads that rust are inaccessible. Second, there's a good chance the heat will set the rubber body mounts on fire.
Well all the body bolts came out with absolutely no issues. I do have a question though. There was one captured nut on each side that was unused and just had a rubber puck bushing pressed into the body. Why is there an unused nut?
would this be right in front of the back tires??was it pressed in the body or just stuck to it?when i had my 66 jacked up to replace the bushings i wondered about that bushing too.so thought well the bushing kit comes with an extra for the convertibles so i put it there.but for the life of me could not get a bolt to thread in,then tried a 3/8 bolt and it screwed in and tightened right up.i have to ask too why did they not use a bolt there??joe got an answer??
Tedd Thompson
January 27th, 2017 12:55 PM
fiebs442
Cars Wanted
August 22nd, 2013 02:37 PM
