Door hinge pins
Old Oct 7, 2011 | 03:53 PM
boondocker's Avatar
Where were you in '72?
Door hinge pins
I just received a full door hinge kit from Tamraz, and I'm wondering how to create the door pin stop similar to factory...looks like a special tool was used...any ideas?
See photo, holds pin in place.
Old Oct 8, 2011 | 09:23 AM
boondocker's Avatar
...testing, testing...is this thing on?
Old Oct 15, 2011 | 06:29 PM
64Custom's Avatar
It looks like a C-clip? Could you mark the pin and then score a groove into pin for the clip. If it only holds the pin in position, there is no stress on the clip. You could also drill the pin and use a cotter pin.
Ken
Old Oct 17, 2011 | 07:46 AM
boondocker's Avatar
Thanks for the response, It looks like some sort of factory tool was used to press in the stops. The Tamraz hinge kit has serations at the head which required me to pound it in...i'm guessing this will hold and seems to work fine, if i have any issues i'll try your cotterpin idea.
Old Oct 17, 2011 | 07:55 AM
RetroRanger's Avatar
72 Olds CS
dont pound the pin in use a press with support to prevent distortion, mine have held fine w gravity and the serated type machining on the end
Old Oct 17, 2011 | 06:35 PM
64Custom's Avatar
I hope it works out. I think the serations on the head of the pin is to prevent it from turning and wearing out the hole. Either way it should stay in place.
Old Oct 17, 2011 | 06:50 PM
Lady72nRob71's Avatar
I pounded mine in straight and carefully on concrete, with a stout socket underneath the pin bottom. Pounding is okay of you do it right. The serrations will hold it.
See? Turn the mic on and the word gets out!
Old Oct 18, 2011 | 05:32 AM
boondocker's Avatar
See? Turn the mic on and the word gets out! [/QUOTE]
I had the mute on...doh!
Ddbord
Jul 13, 2010 05:39 AM
Ranzan
Apr 24, 2010 06:55 AM
ChrisM
Nov 16, 2008 05:34 PM
dyscookn
Feb 16, 2007 12:24 PM
polcatt
Oct 8, 2006 07:03 PM
