Door assembly without removing Fender? Help!!
Old Jun 29, 2012 | 09:54 AM
dancutlass's Avatar
Question Door assembly without removing Fender? Help!!
Hi,
I was curious, if it is possible to assemble the doors, with the fenders already installed. I looked at it today and it seems as if it is impossible.
I'm talking about a 66 Cutlass convertible.
As always any help will be greatly appreciated!
Thanks!
Old Jun 29, 2012 | 10:56 AM
Run to Rund's Avatar
I would consider it impractical. The door is heavy and has to be positioned exactly, held that way while bolts are tightened. Access to the bolts is poor with the fender installed. I would have the hinges on the doors and install them with the fenders off. You can make a stud for one bolt position to help you position the doors, then remove the stud. I weighed my sedan door at 74 lb.
Old Jul 1, 2012 | 05:59 AM
dancutlass's Avatar
Thank you very much, good that you said it before I tried it I did it the way you recommended and all went well! Thanks
Texas442
Oct 8, 2014 02:59 AM
stratoblues
Sep 1, 2014 06:52 AM
roberer
Aug 8, 2014 08:14 PM
Gunfreak25
Feb 11, 2011 02:44 AM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
