Bleeding/Filling Convertible Top Motor and Lines
Old Mar 26, 2015 | 02:38 PM
leroycjr's Avatar
Hi folks,
Have a convertible top question. We're putting things back together now looking good cant wait to show pics but I have a concern. When lowering the top I noticed that there is a lot of air going through the top lines and at some point on the way down I see no fluid going through the lines and of course the tops slooooooowly goes down. I stop trying to put it down so I don't burn out the motor.
My question is this. I had someone replace the hoses and so I know there is tons of air in the line. I've looked at the cryptic Fisher manual and does anyone have a easier way to FILL and PRIME the lines! OR do you have a craftier way of creating the hose that needs to be put into the motor. Looking for ideas as i want to do this next week.
Help would be greatful.
Old Mar 26, 2015 | 03:02 PM
jcmoretti's Avatar
I remember reading that part of the manual when I broke a hydraulic line while working on the interior. I was confused.
Ultimately, I added fluid using some clear tubing and one of those colored ketchup/mustard squeeze bottles that my wife bought for parties. I didn't make the fancy plug the manual calls for.
I simply don't recall whether the air bubbles worked themselves out or not. But the top works, well except for the holes in it!
Old Mar 26, 2015 | 04:04 PM
m371961's Avatar
I disconnected the cylinders from the top frame, run them in and out and checked the fluid often as I did this. (they did not extend the same rate, one opened before the other) Used a squirt oil can to fill. Then as I saw less air, I hooked them back up and and did the same thing. Eventually I saw little air in the lines, topped it off and left it. I believe Hydro-E-lectric had instructions on line.
Old Mar 26, 2015 | 05:08 PM
So what is the recommended fluid? ATF?
Old Mar 26, 2015 | 06:31 PM
QMaster's Avatar
Yes, ATF works. I had to replace a cylinder last year. I used the Hdro-Electric instructions and they worked fine.
Old Mar 27, 2015 | 06:00 AM
68442's Avatar
68 - up used ATF
67 - Down uses brake fluid
Old Mar 27, 2015 | 03:13 PM
m371961's Avatar
If pump and cylinders are replaced ATF can be used. I would think if all is removed you could flush out the brake fluid and replace with ATF, but don't know for sure.
Old Mar 28, 2015 | 05:22 AM
68442's Avatar
Yes, that is correct.
Old Mar 28, 2015 | 04:20 PM
tmaleck's Avatar
My new pump and hydraulics specifically said brake fluid would work but void lifetime warranty.
Tim
Finn5033
Oct 10, 2022 08:08 PM
kens69olds
Brakes/Hydraulic Systems
Sep 1, 2014 07:15 PM
chasman414
Jan 7, 2013 07:19 AM
tomdiet
Sep 5, 2012 07:22 PM
silverriff
Dec 4, 2008 01:51 PM
